I have a Whirlpool LSN1000JQ1 washing machine and it makes a clang, clang sound when it's spinning out and during agitation. During the spin cycle the drum will spin just about an inch then you hear the clang noise, then the drum spins another inch and then you hear the clang noise. It goes like that. Can you help please. The washer is about 8 years old.
SOURCE: Washer will not Spin during SPIN CYCLES
Thanks for the question If your washer sorta spins and washes ok, your problem is with the transmissionTHanks for your question THe Appliance doc
SOURCE: Whirlpool Duet: gray plastic agitator poece inside drum broke off
here's the part number for the replacement 8182233, thinking it may come as a 3 pack , if they're not broken no need to replace. but the new one will simply slide in and with a click forward lock into place. they also come shipped with a screw to secure. in order to install screw you'll need to remove the top of the washer(3 screws across the back of the top assy and slides back and off. then you'll see the top of the tub area, a small black hose will run from the white box to the left to directly top of the tub assy. remove ethe hose from the tub and spin the inner drum to the correct position, they screw hole will line up through the opening, re-secure the hose to the tub and your in!
SOURCE: does not agitate
Agitation is the most complex operation in any washing machine. There are several components working together to make it agitate and as a result it is a challenge to isolate the problem or problems involved. Here is what to look for:
If your washer doesn't agitate, check these:
Lid switch
Motor coupler
Belts
Clutch
Drive motor
Drive pulleys
Transmission
Agitator
Lid switch
If the lid switch is defective, the washing machine may not agitate or function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Motor coupler
Many washers produced by Whirlpool® use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. If this happens, you need to completely replace it.
Belts
Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
Clutch
If your washer was made by GE®, it may use a clutch for agitating the clothes. As the clutch wears out, it may prevent the washer from agitating well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
Drive motor
Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
Drive pulleys
The motor or transmission drive pulley may be worn and unable to turn the drive belt. If so, replace the pulley.
Transmission
The transmission could have either of these problems:
If you suspect a transmission problem, you may have to call a qualified appliance repair technician to repair it.
Agitator
The inside of the agitator--where the transmission shaft attaches--can become worn, and strip out the spline that allows the agitator to properly grip the shaft. Then the transmission shaft rotates back and forth as it should, but the agitator doesn't move properly. If this happens, you may need to replace the agitator and/or the transmission spline.
