Fish Logo
Anonymous Posted on Feb 20, 2013
I have a fish pond and our new puppy has pushed some of the rocks surrounding the pond into the pond and has torn the liner. What is the best way to repair this.
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 8 Answers
  • Posted on Feb 20, 2013
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
8
Questions
0
Helped
1332
Points
20
Drain fish pond see what kind material the liner is made of and trouble shoot get a bulge pump pump the water into something that can hold it maybe like a kiddies swimming pool or something like a bigger yard swimming pool for fish and water wlmart sells swimming pools
Where can I buy pond sticks for my fish?
Amazon have a good selection of pond sticks and pellets and other fish food. http://www.amazon.co.uk/b?ie=UTF8&node=471519031
Aug 26, 2012 • Archos Fish
When do i add fishes to the pond
you should wait a week to make sure that everything is stable in pond and add your fish, avoid too many fish and overfeeding them. enjoy your fish pond, i love them.
1helpful
Leak in formed pond
It worked for one season on mine. As the crack got older it became longer and wider. Mine was due to not sinking the pond all the way into the ground which caused stress from the weight of the water causing it to crack more. The second season I used a water epoxy putty I bought at home depot in the glue dept. It is greenish blue and turns white after mixing and can be used underwater if necessary. I filled the gap and then placed the repair liner like you are showing over the top and sealed the edges with a black waterproof silicone. This also worked for a season. Now the crack is even larger and wider and nothing I am doing this year is holding! I can't seem to find one the same size and shape or I would replace it. My next attempt is going to be a plastic welding kit, but I haven't tried it yet. Good luck.
LAST FALL IN EDMONTON CANADA WE HAD ALL KINDS OF LONG STRING GREEN ALGIE GROWING IN THE POND. STILL GREEN WHEN WE UNCOVERED POND THIS SPRING. HOW DO WE KILL IT OFF AND KEEP IT OFF THE ROCKS...IT EVEN SEEMS...
they sell algae killer for ponds and water nurseries and some pet stores that u measure a dose for pond size and add to water to clear up. if there are no fish and don't plan on having fish in pond add several gallons of bleach as cheap cure
1helpful
2answers
My pond is loosing water. I think there might be a small hole in the liner,but Ido not know where. Is there a seelant that I can get
There is sealing options once you discover the hole or tear. Allow pond to drain down to it's stable level and investigate. The liner material will dictate what your repair options are. Firestone Pond Liner or Pond King EPDM liner can be best sealed with a piece of "cover" tape - a single sided heavy repair option that bonds very well. Clean with a epdm solvent first or Coleman fuel if you can't find that. The solvent makes EPDM very tacky (wear gloves) application is much like fixing a bicycle tube.
Mar 02, 2009 • Garden
Question before purchase (existing pond)
You don't need a bulkhead if your liner is EPDM. You can use a boot that is attached with adhesive that will seal you pvc piping. I don' t see a problem with dirty water going thru the pump before the filters. for some diagrams of settling tank installations see:
http://www.koipondfiltering.com/koi_pond_filters_diagrams_intermediate.html
1helpful
Pond pump not working
Well first thing is to locate pump and then check to see if the screen is plugged. turn power off and check inlet tub of pump for sticks, rocks,or leaves in it that can plug the suction on it
Nov 21, 2008 • Garden
Top Fish Experts
Keith
Level 1 Expert
ADMIN Andrew
ADMIN Andrew
Are you a Fish Expert? Answer questions, earn points and help others
