Question about E-Machines T6520 PC Desktop
Radeon 6570 graphics card any reported problems with emachine T6520
Is a radeon 6570 graphic card compatible with a emachine T6520 desktop
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 29 Answers
Yes as long as your T6520 comes with at least a 400 watt power supply. It has the required 16x PCI Express slot.
Posted on Feb 20, 2013
SOURCE:
  • 239 Answers
SOURCE: installing radeon s9259 graphics card on a emachine t5010
Did you try to after you install the card to go into the control panel and install new hardware in the add new hardware. If I understand you, when you plug the monitor into the new video card it does not turn the monitor on, Even after you install the card and reboot your pc with the monitor plugged into the new device it don't come on, Make sure the old one is disabed in the device manager and it should work, If Not I need somemore information, You should not have to have changed it in the bios, you may want to change that back to the way it was, the radeon is compatible with the emachine and should work just by installing and plugging into it,Try that see what happens.Hope it helps Happy Holidays Just write back here if that don't work and I 'll figure it out for you,
Posted on Dec 15, 2007
jyvibar
  • 148 Answers
SOURCE: Soundcard/video card advise for emachines pc.
you can install a PCI vedio card to enhance video quality. a 128mb will do the thing. The integrated sound card you have is good enough, to maximise the sound install good quality speakers with subwooper or boosters
Posted on Mar 21, 2008
  • 25 Answers
SOURCE: Can I upgrade my graphics card?
they do sell pci express 1x slot video cards, is it really much of an upgrade?? no
however here ya go
http://www.bizrate.com/graphicscards/matrox-millennium-g550-32-mb-pci-e-graphics-card--pid608664132/compareprices.html
Posted on Feb 15, 2009
  • 1015 Answers
SOURCE: eMachine Video Card upgrade
Ok so are you getting video from the card? Look in system information and see what graphics hardware the computers says is installed. Are you replacing a video card or did you add a card to the system? If you are adding a card make sure that you change the settings in the BIOS to boot first on AGP/PCI-E express slot. Make sure that fast write settings and bus speed settings are compatible with your card. For example if you purchased a 8X AGP card and your computer only does 4X the card may not work. Double check that you are trying to install the correct drivers for your card and operating system.
Posted on Sep 12, 2009
Zenodilodon
  • 145 Answers
SOURCE: My pc name is el1333g-01w and i need help
Google both "PCIe" and " AGP " in images to see what one best matches your old graphics card. After that you can go on newegg.com or another electronics store, even possibly a bestbuy and purchase a card with the same style of port. If you do not have a PCIe or a AGP slot on your machine then you may not be able to upgrade the graphics.
Posted on Apr 23, 2010
Trouble with install second video card HD 5450 to emachines t6532
Unclear of your statement. (More like run-on sentence)
Problem heading statement reads,
"trouble with install second video card HD5450 TO eMachines T6532"
Need clarification
The eMachines T6532 Desktop PC uses an MSI MS-7207 motherboard.
Also known as the MSI K8NGM2-L,
http://www.msi.com/product/mb/K8NGM2-FID--IL--L.html
(Click on photo for a better image)
Has one long white PCI Express x16 slot. (Expansion Slot)
Only uses one graphics card at a time, will Not use two.
[Graphics card / Video card. Same/same]
Therefore I surmise you are not referring to adding a Second graphics card, but are referring to;
A) This is the second time you have added a graphics card.
Or,
B) This is the second ATI Radeon HD5450 graphics card.
Had one before. Removed it, and are using a new one.
Or,
C) This is the second time you have added a graphics card.
It is not an ATI Radeon HD5450 like the old one is.
Know this;
1) You can ONLY use the OnBoard (Integrated) graphics,
OR the graphics card.
You CANNOT use both.
When using a graphics card the monitor is plugged into it.
You cannot plug into the onboard graphics of the motherboard, with it installed in the computer.
Said differently;
With the graphics card physically installed in the computer, you cannot just unplug the monitor from the graphics card; and plug it into the OnBoard graphics of the motherboard.
[Also; Computer on, you CANNOT unplug a monitor, and plug it back in.
This = NO ]
2) Driver: Small piece of software that allows the Operating System to communicate with a device.
The device is the graphics card.
The version of Windows operating system was not stated.
Did you install the software from the Installation Disk? (CD/DVD)
Has the drivers on it, and the user interface software.
User interface software for an ATI graphics card, is Catalyst Control Center.
(Just to note; I'm using a Powercolor Radeon HD5450 graphics card, right now.
I'm using dual monitors.
HP 2009M - 20 inch widescreen LCD monitor, and an RCA L26HD31 HDTV as the main monitor. (26 inch HDTV)
They work GREAT! ]
(It is an ATI Radeon HD5450 graphics card just like yours, IF yours has 1GB of graphics memory.
Doesn't matter what graphics card manufacturer, makes that HD5450, it is still an ATI (AMD) design.
Powercolor, VisionTek, Sapphire, Diamond Multimedia, Mickey Mouse, or Goofy. It is still an ATI graphics card )
The ATI Radeon HD5450 graphics card, has to have a MINIMUM power requirement of 350 Watts.
Does your power supply have 350 Watts or more?
If it is the original power supply, the answer is NO.
Back then power supply manufacturers were 'fudging' the true maximum rated wattage.
Why?
Sold more power supplies.
Power supply rated at 250 Watts?
Nope.
More like 60 to 70 percent of that.
Divide 250 by 10.
= 25.
Take that times 6. = 150 Watts (60 percent)
Times 7 = 175 Watts (70 percent)
Would like your opening statements clarified.
Post back in a Comment.
Regards,
joecoolvette
Mar 15, 2013 | E-Machines eMachines Desktop PC
When I boot up my emachines desktop half of the screen is black
Possible causes of this problem include:
1.) A loose connection either of the graphics card or the cables to and from the monitor/graphics card.
2.) A faulty graphics card.
3.) A faulty monitor.
4.) A bad Graphics driver. See this guide entitled How to install Graphics Drivers, Nvidia and AMD Radeon!!!
Remove the graphics card and clean the gold fingers with tissue paper. Clean as mush dust as you can out of the system.
See My Computer is not turning on!!! Is it dead!!! No POST!!!, for further information.
Take care!
damnor01
Apr 27, 2011 | Computers & Internet
What dual video card is compatible with the M52?
The 256MB ATI Radeon HD 2400 XT Dual-VGA or Dual-DVI, TV-Out Graphics Card (43R1962)
The 128MB ATI RADEON X300 VGA, VGA PCI-e Dual Head Graphics Adapter (40Y8405)
The 64MB NVIDIA GeForce 6200 VGA PCI-e Dual Head ThinkCentre Graphics Adapter (73P2517)
The 256MB ATI Radeon X1300 Dual-VGA or Dual-DVI, TV-out PCI-Express Graphics Adapter (41U5028)
The 128MB ATI RADEON X300SE Dual-VGA or Dual-DVI Dual Head ThinkCentre and Lenovo PCI-e graphics adapter (41U4813)
The 128MB ATI RADEON X700 VGA, DVI-I, TV-Out PCI-e Dual Head ThinkCentre Graphics Adapter (73P2518)
All above are compatible with the ThinkCentre M52. Hope this helps, Best Regards, - md
Nov 10, 2009 | IBM ThinkCentre M52 8113 - P4 551 3.4 GHz...
Ok, i have two things to ask 1: Where is the video card on a emachines W3503? 2: Could a video card swap be done between a W3503 and a W3052? Thank you for viewing :)
1. The emachines W3503 has an integrated ATI Radeon™ X300 based graphics card. It has also a PCI Express (PCIe x16) slot available.
2. The emachines W3052 has a NVIDIA® GeForce®4™ MX graphics card. I'm not sure whether it is integrated or not, but I'm sure that if it is not, it will be an AGP graphics card. Since The emachines W3503 has a PCI Express (PCIe x16) slot available for installing a graphics card, the swapping of graphics cards between the 2 machines is not possible since they support different types of graphics cards.
Jul 11, 2009 | Computers & Internet
Cannot play FIFA09
Uh oh. It looks like you're out of luck.
FIFA 09 PC Requirement (minimum):
Graphics: 6600 Nvidia graphics card or ATI equivalent with support for Pixel Shader 3
DirectX Version: DirectX 9.0c"
Nvidia 6600 came out at 2004 and it supports DirectX 9.0C (Shader 3 came with 9.0C)
ATI Radeon 9200 came out at 2003 and only support DirectX 8.1 (which support shader 1.2 - 1.4)
Nope, Radeon 9200 will not support Shader 3 (neither will it support 2.0).
Time for a new video card maybe?
I hope this answers your question.
Mar 16, 2009 | ATI RADEON 9200SE Graphic Card
More compatibility problems ?
what you will need to do is accertain which cpu format you have in your machine and find out if you have pcie 1 or 2
regards rich
Feb 24, 2009 | Dell Dimension 9100 PC Desktop
Graphics Card Card
you should be fine with the PSU that you have currently got but i would recommend upgrading it to something above 400W.
there is a graphics card i would recommend which is a Sapphire ATi Radeon HD 2600 PRO. you can look it up here.
it will support dual monitor at 1080p which uses two DVI.
Dec 26, 2008 | Computers & Internet
Radeon X1300 - Windows has stopped this device because it has reported problems
As far as I am aware, you can not run an ATI card in the same system as an Nvidia card due to driver conflicts.
Oct 30, 2008 | ATI RADEON X1300 Pro 256MB PCIE Graphic...
Problem with radeon 9200 graphics card
i had a radeon 9200 graphics card, so i switched my graphics card to another one i had which is a nvidia geforce fx 5500 and updated the driver and now everything seems to be working fine. i don't know if it was my radeon 9200 that was just not compatible to play the game i wanted to play or not
Apr 21, 2008 | Computers & Internet
Installing radeon s9259 graphics card on a emachine t5010
Dec 15, 2007 | E-Machines eMachines Desktop PC
E-Machines T6520 PC Desktop Logo
67 people viewed this question
Top E-Machines Computers & Internet Experts
Ekse
Steve Allison
Steve Allison
Thomas F. Schneider
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
