Question about Homelite Consumer Products 4.0 Amp, 13 In. Trimmer
Need manual for homelite sx-135 weedeater
Need to know how to wind the string for this homelite sx 135 and we need a manual
  • Anonymous Apr 19, 2009
    how do I dismantel string holder to put new line on?
Http://www.homelite.com/service_support/order_parts
Posted on Apr 16, 2009
SOURCE:
Homlite string trimmer sx-135 ut-20609 a ratio gas & oil mixture
You should mix 8 Oz. of two cycle oil to one gallon of gas. I put the oil in first and then the gas and it will be mixed and ready to go.
Jun 08, 2016 | Homelite Garden
Need to change the weedeater line.
There should be a half sphere-like object on the bottom of the spool where the line goes. Twist counter clock-wise to remove.
If it is a duel line trimmer then:
Cut two separate pieces of string, about 7 ft. each.
Stick the end of the line in the hole on the inside of spool.
Wind clockwise onto spool, putting the line that is closest to the ground on first.
Once you have winded this piece on, lock the last 4 inches of line through the slits on spool.
Repeat process for second piece of line, locking the last 4 inches in slot opposite the other locked in piece.
Put the spool on the trimmer, feeding the end of lines through either hole on trimmer.
Before you push the spool all the way on, pull the strings out of the locked position.
If it is a single line trimmer: Then just wind a single piece of string clockwise onto spool. This may need to be longer than 7ft.
Jim
Sep 29, 2010 | Homelite Mighty Lite Lawn Trimmer
Restringing a homelite bandit trimmer
What is the correct size of the nylon cutting material - on my homelite bandit SX-135 trimmer ?
Thanks, Bill.
Apr 30, 2010 | Homelite Consumer Products 4.0 Amp, 13 In....
Bgreen. Need correct part no. for primer bulb for sx135 bandit string trimmer. old one has cracked due to age.
Your SX-135 string trimmer was built by Homeliteand has a model number of UT-20601. That said, your trimmer's primer bulb part number depends on teh type of carburetor it has. If your trimmer has a Walbro carburetor, the primer bulb part no. is 01201. If it has a Zama carburetor (the most likely one) the primer bulb part no. is A01195A.
You can go to the following website to order the part: http://www.homelite.com/service_support/order_parts
Good Luck, hope this helps!
Oct 15, 2009 | Garden
Homelite st-175g trimmer
This is for a duel line trimmer. I hope this will help.
Before you push the spool all the way on, pull the strings out of the locked position. Put cap on and GO CRAZY!
Jim
Jun 17, 2009 | Homelite Mighty Lite Lawn Trimmer
Need string for Homelite trimmer (Model UT20042)
Genarally the size of line for that size of line trimmer is 2.0mm
May 07, 2009 | Homelite Curved Shaft Trimmer Bump Feed...
Oil to gas ratio
heres a link for homelite service manual
http://www.odref.com/homelite/string-trimmers/service%20guide.PDF
pg 4 states that fuel/oil mix is 50;1
2.5 oz per gallon
Apr 20, 2009 | Garden
Homelite Consumer Products 4.0 Amp, 13 In. Trimmer Logo
8,448 people viewed this question
Top Homelite Garden Experts
roeb
Jay Finke
Jay Finke
Randy Schumann
Randy Schumann
Are you a Homelite Garden Expert? Answer questions, earn points and help others
