If you receive an E3 Error code, your washer may be unbalanced. This could be caused by the washer being too tightly packed, or clothing not distributed evenly. This will usually occur during the spin cycle. Stop the spin cycle.
F8 is taking too long to fill. Check the filter screens on the rear hoses.
The F8 E1 or Lo FL error code means your washer is not detecting the correct amount of incoming water. If the washer has an F8 E1 error or LO FL error, the door may be locked, and the control may be unresponsive. Aug 21, 2023
E1 flashing means that the product's firmware/software needs to be flashed or repaired again in order to function properly, this generally occurs due to inadequate voltage supply or sudden power failure of the Oven.
i'm sure you already found out that you have or had a bad thermister located on top of the blower wheel housing,just answering this in case somebody else has this problem.e1 error code is bad thermister
Error E1 indicates a thermistor failure.
The dryer will not operate if the exhaust temperature drops below 18 degrees F. or exceeds 250 degrees F.
When the thermistor circuit is open (>50K ohms), the error code E1 flashes in the display.
Normal thermistor resistance values:
60 degrees F. - 15.3K ohms.
70 degrees F. - 11.9K ohms.
80 degrees F. - 9.2K ohms.
Take the top off the dryer and inside you'll find the "tech sheet." It has instructions for removing the front panel and locating the thermistor.
