Burberry Authentic BU1321 Womans Swiss Quartz Watch Logo
Arthur W Levio Posted on Feb 19, 2013
How do I remove the back of this watch?
Does this watch need a special removal tool to take the back off?
Marcelo
Level 1:
New Friend:
Greenhorn:
A rookie expert who has answered 20 questions on their first day.
  • Contributor 60 Answers
  • Posted on Feb 20, 2013
 Marcelo
Contributor
Level 1:
New Friend:
Greenhorn:
Answers
60
Questions
0
Helped
25464
Points
85
I have seen other burberry watches and the back should pop out .
1- Locate a very small tab or recessed area on the edge of the back cover 2- Pull out the stem, which releases the back on some watches.3- Get a small flathead screwdriver it needs to be a thin inflexible tip 3- Very carefully slide the blade under the tiny metal protrusion on the back cover (or across the length of the recessed area, depending on which type of cover your watch has). 4- When you replace the cover, make sure you line up the stem slot on the cover with the stem of the watch. This information is on wiki: http://www.wikihow.com/Pry-off-a-Watch-Backing-Without-Proper-Tools
1helpful
If you dont have the proper tool whats the best thing to use for getting the back plate off back plate off your wristwatch
Robert,A hammer works, not well, but it works! The caseback on your watch is installed/removed in several different ways. Some are a 'snap back' where pressure is applied and the back snaps in. Some are 'screw backs' and require a special tool to remove them, sorry, no substitutes for the special tool here. There are others as well and some watches look like they have a back but don't. The parts come out of the top instead. There is no substitute for the 'proper' tool. Don't hit your thumb with the hammer!
Oct 11, 2012 • Watches
Timex fmdpu004 How do you remove back of watch
The watch you're talking about has a snap on case back. They make special tools to remove them but any sturdy, thin piece of metal should work to pry it off. The trick will be to get it to go back on. That can be very difficult and you may need a special press to get it back on. If that is the case, I'd take it to a jewler and have them doo it.
1helpful
Hi. I have a DKNY watch NY4791. How do I remove the back to change the battery. Does it require a special tool that only a jeweler or watch repair would have? Thanks. -Susan.
Hi Susan, most Watches will require a tool to remove the back, some use a knife like tool, and some use an adjustable key type tool to fit the slots of the watch cover, so that you can unscrew the back off. Sometimes you can use a thin knife too, be very careful not to cut yourself, and also not to damage the rubber gasket. The gasket sometimes will need replacement on some watches if they are waterproof. I recommend having a watch expert look at it if you feel you can't do this yourself.
Also the tools are available on eBay. I hope this helps you. Joe
How to remove the back of a watch to replacae the battery
mcdevito75 here, A special tool may be needed to press the back cover back onto your watch, no one can tell until the back cover is removed, this could be the case with your watch, if so, you"ll have a problem. BEST BET, look for a small watch repair shop in your area, the cost will be the same if you need this mentioned tool and anyway, the battery change is once a year or even longer
Feb 11, 2011 • Watches
1helpful
Need to know how to remove back from guess waterpro mens watch
Takes a special tool to remove back off watch. You can buy the entire watch tool kit online for about $65. OR, you can send to Guess (best option as it will keep the waterproofness intact) for about $11.50 (see link)http://www.guesswatches.com/pdfs/WarrantyBooklet_GuessWatches.pdf
How to remove links from times watch band model #tx1282
mcdevito75 here, You"d need a special tool available on ebay called a link remover tool. But for fastest remedy and just about the same cost as buying and shipping the special tool, unless your going to do a few watches, your best bet is to look for a small watch repair shop in your area to remove these links, hold onto them just in case you need them later.
1helpful
My Timex automatic gains a bit each day. Can I adjust it?
Most watches have some sort of adjustment but I would advise you to take it to a Timex dealer as removing the back can cause problems (particularly with the waterproofing seal).
Also, I could not see the back of the watch in the catalogue but many watches need special tools to remove the back.
Second hand came loose inside watch. How can I remove the glass on the face so I can get it out of there?
I suggest that you take it to a watch shop. Removing the glass is not a good idea, as the seal will be effected. Watches are made to be accessible from the back but special tools may be required.
All in all, it is safer to leave it to those who have all the special tools and experience.
Jan 20, 2010 • Watches
Need to remove back of watch
If you are shure that your watch has a removable caseback then you have to use special case opening tool (looks like knife with very short and curved blade). Insert blade into the groove and applying great and steady pressure turn the opener upwards. The back should come off. Make sure the blade doesn't slip, oterwise you will damage the movement.
As your watch model is obsolete, I compared it to MQ24-7BLL and find that this movement should be opened from the front- First the glass must be removed, then stem with crown and then movement itself. In this case you will not be able to do it yourself as special tool for removing glass is needed. If you will try it anyway, you will end up with snapped glass as it is set with great pressure to make case water resistant.
Regards
Arthur
Top Burberry Watches Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Burberry Watch Expert? Answer questions, earn points and help others
