Pus the button and the DVD player will not open or/or it will not do anything. The DVD compartment will not open to insert the dvd
SOURCE: Background color is orange instead of blue, color is messed up
Usually this problem is a simple one to find out.Are you wires working correctly.If they are not,open up the box and,if you are a professional so I dont get sued for some accident,try to splice the wires back.If your not a pro take it to the retailer and have it fixed.If it is not the wires,I would check your color settings option in the DVD options menu.Check your red blue green balance and make sure they are correct.
SOURCE: DVD PLAYER DISC TRAY DOES NOT OPEN
tap it gently from the side while pressing the button......or with a knife try to open it gently...while pressing the button....after it,s open..clean the side n the belt..
SOURCE: Can't open the DVD door
you'll have to remove the top and remove the disk that way. there's a top bracket on the dvd drive to remove before you can get to the disk. and unplug the unit first!!
SOURCE: player won't open. how do we reset?
my dvd player is stand on the red light when i insert the dvd the dvd will hand after few seconds what is the problem please solved my problem
SOURCE: Philips 3360H - can't eject DVD
Try this..turn it off, unplug it for a min or two, then plug it back in. THEN...if the power stays off...hit the eject/open/close button on the panel.
Sometimes this activates the eject mode without turning on the unit. IF NOT, try the remote eject without turning on the unit.
