PIXILATES, THEN GOES BLACK, ON AND OFF AFTER ABOUT TEN MINUTES?
Hello Kevin,
That type of issue is usually caused by bad filter capacitors on the power supply board. As the capacitors heat up they can't filter the output power correctly so the power supply shuts off to prevent damage. Here is a link to information and parts list of the capacitors neede3d to repair the power board.
http://www.ccl-la.com/catalog/product_info.php?products_id=323
sorry...sound goes out too
It seems to be tuning right off then on, sometimes for a few seconds only the backlight is lit other times just black, but it all starts out with the picture starts to pixel-ate(sp)
it's a magnavox 32MF231D tv
Works perfectly whrn back is off with fan blowing so something must be overheating, but not sure what that might be. Anybody??/
Hi Buddy,the caps aren't swelled, could it also be the thermo-paste on the transistors on that same cirquit board? I already decided it WAS that board.?ThanksI have thermal paste, but if your sure, then I won't try that first. Thanks again Buddy. ...Kevin
