I purchased a truck in a Box all apart and now I am putting to together and I don't know if I am putting the bed together the right way.
Most bed frames you buy come with assembly instructions. Assembly is usually very simple. Usually most of the frame is put together and all you have to do is link two parts in the middle of the front and back of the frame.
KWP2000
SOURCE: power seat motor broken
Yhea you have to disassemble the entire seat and order a new base for it. We have repaired a few of them at the shop. I have had one just welded back together but it never sits quite the way it used to.
SOURCE: 1998 GMC Sierra (C1500) 5.0L 305 V8-right rear brake line
i dont know of any recall for that
and yes it can be replaced without removing the bedeasy wasy too do it is go too auto zone and buy a roll of brake line and run it along side of the old one and just leave the old one in the hangers and use tie straps too hang the new one!!!
SOURCE: Drivers door window is off it's carrier Rail
Remove screws by mirror, and around the door armrest, use a flathead screwdriver to pop out the electric window/door lock controls and unplug the wire harness. Now take a bigger flat head screw-driver and pry around the edge of the panel where there are little plastic retaining screws. Pull slowly and make sure screw-driver is directly next to plastic screw. Now, pry all around the edges, and pull the panel straight up and pull than set it on the ground. You will now see the inside of your door. There may be plastic covering over the door that you will have to slowly pull off or cut. Now you will see your window. There should be a carrier rail on each side of the widow or straight across the bottom holding window in place. Re-align window to holder, (if there is any broken parts, you should get them replaced) You can turn car power on and still use and re-plug in window control buttons to help adjust the carrier rail.
Now reverse procedure for replacement.
SOURCE: 1987 S10 2.5L 4 cyl.
Check the spark either with an inductive timing light, or with an old spark plug in a wire you disconnect and lay on the engine.
It is probably the coil or ignition modules, which most parts places will check for free, if you bring it in.
Jacking points on all Jeep vehicles
Your Jeep was supplied with a jack for emergency road repairs. This jack is fine for changing a flat tire or other short-term procedures not requiring you to go beneath the vehicle. Do not attempt to use the jack on any portions of the vehicle other than specified by the vehicle manufacturer. Always block the diagonally opposite wheel when using a jack.
Placing a floor jack under the front frame rail
Placing a floor jack under the rear frame rail at the leaf spring shackle. It may be necessary to place a block of wood between the frame rail and the jack
Supporting the front of the vehicle with jack stands placed under each frame rail
A more convenient way of jacking is the use of a garage or floor jack. You may use the floor jack at the specified points in following the illustrations.
Never place the jack under the radiator, engine or transmission components. Severe and expensive damage will result when the jack is raised. Additionally, never jack under the floorpan or bodywork; the metal will deform
Support the rear of the vehicle using jack stands placed underneath each side of the rear differential (inset photo)
