I had recorded successfully on Saturday until Casualty then on all the recordings are very blurred. Is there anything I can do?
SOURCE: Recording problem with LG RH266 Recorder..
Just bought unit. Had same problem.Tried lots of different types of disks with no luck. Tried to play already written +R disk. Worked OK. Then took out and replaced with blank -R. Came up with new screen asking me if I wanted to initialize disk. Answered yes and it took about 20 seconds. Then tried to DUB from HDD to DVD again. This time it came up with the dubbing menu, I hadn't seen before, and worked.
Hardly ideal, but the trick was to get it to recognise it as a blank and initialize. Currently burning my first disk. Didnt realise about 'FAST' mode, so taking ages.
SOURCE: region free unlocking code for LG RH2T80 DVD Recorder
Goto 'Setup'
Scroll to 'Lock' (don't scroll sideways from here)
press '0' seven times
press 'Enter'
SOURCE: lg dvd recorder
No, this is a fault with the unit, 99% of the time caused by the power supply, but I've seen it be caused by the MPEG pcb
SOURCE: LG RH399H
I've had "Record-blocking signals detected" on my LG RH398H-M recorder off & on since I bought it almost a year ago. Also other minor problems. LG replaced the recorder 4 times with no change in problems. I became suspicious when I found that when these messages came on I could switch to any channel, digital or analog, even the weather channel, and I would still get the same message for about 5 minutes & then everything would be OK again. Recently I finally got the chance to try something. When the message came on I disconnected the input to the recorder and the message still came on! Again, I got the message "Record-blocking signal detected" with ABSOLUTELY NO INPUT CONNECTED to the recorder!!! Of course it's impossible for the recorder to be receiving blocking signals when there's nothing connected to the inputs. I wrote to LG again and threatened a law suit but so far they've been ignoring me. I would like to hear from anyone who can duplicate the above.
SOURCE: Stop Substitles on a LG RHT497H 160G dvd recorder?
I have the LG DVD recorder DRT389H which has the same problem. You can't switch off the subtitles during timer recording from the Electronic Programme Guide. The only way I could stop this was to go to the main set-up menu then select the A icon. Select DTV Subtitle and choose a language that the TV programme isn't broadcast in. I chose Gaelic. The only disadvantage is that this stops any subtitles being recorded so you can't access them later.
