Trying to turn the heater on the Spa. Manual states to turn Spa button to on as well as heater for spa. When turn on the Spa button, all water drains thru filters/pumps in to the pool. How do I turn this function off and just turn spa filter on as well as spa heater on.
Here is a link to the Aqualink website so you can download a trouble shooting guide.
I need a manual to program the controller, how do I get one?
I am trying to heat my spa only. The overflow feature to the pool is continuing so there is a constant exchange of water with the pool. The heater is working fine but because the waterfall does not stop, the temperature has only gone up 4 degrees in 4 hours. Help!!
I have the same problem when i enable the spa heater then push the spa button, the spa drains into the pool. How to solve this problem???
new lay z spa pump heater not heating up water
The water went into pool and did return to spa pool,run over
How do I turn on the spa heater
