If your Rayburn stove is tripping the thermal cut-out when it reaches temperature instead of cutting out and restarting automatically, there may be a few different causes.
- Check the thermostat: Make sure the thermostat is properly calibrated and functioning correctly. If it is not, it can cause the stove to overheat and trip the thermal cut-out.
- Check the thermal cut-out: Make sure the thermal cut-out is not faulty. If it is, it may need to be replaced.
- Check the temperature control: If the temperature control is not functioning correctly, it can cause the stove to overheat and trip the thermal cut-out.
- Check the combustion chamber: If the combustion chamber is dirty or blocked, it can cause the stove to overheat and trip the thermal cut-out.
- Check the flue: If the flue is blocked or not functioning correctly, it can cause the stove to overheat and trip the thermal cut-out.
- If none of the above steps work, it is possible that the stove has a more serious problem that requires professional service.
It is important to refer to the user manual or contact the manufacturer for specific troubleshooting steps for your Rayburn stove model. It is also important to make sure the stove is not plugged in before attempting any troubleshooting steps. If the problem persists after trying the above steps, it is recommended to have a professional technician to look at the stove and diagnose the problem.
Hotpoint FDEU 9640 washer dryer - stops during dry cycle with all LEDs flashing amber Hotpoint FDEU 9640 washer dryer - stops during dry cycle with super wash, slow spin, time saver, eco wash and start/pause buttons all flashing. Spin light is steady on. Then about 5 mins later the door unlocks. Wash cycles complete with no apparent issue but drying cycles are stopping prematurely. I have tried auto clean but this trips the electrics. Checked the pump and pipes no blockages. I have opened up the heater unit and that looks clean plus the seals and connections all visibly look good but I don't have a multi meter to test. Please help with any advice - thanks
