Question about Sennheiser RS 110 Consumer Headphones
Headphones keep going quiet.
Battery operated headphones start off great with good volume, but after 5 minutes gradually die down until there is little to no sound at all. Green light on the base is still on, sound isn't cutting out and hissing due to inactivity, just keeps getting quieter and quieter. Turn up the volume on the headphones and the TV to max and still barely audible. Bought 3 days ago, shouldn't be an issue with battery. Worked fine first couple of days, now this. Anything I'm missing or will I have to return them?
  • Sennheiser Master
  • 1,830 Answers
I would return them and either get a new one from them or another manufacturer.
Posted on May 11, 2017
4 Suggested Answers
SOURCE:
pctech1
  • 1940 Answers
SOURCE: I have a huge problem
The volume of the sound source (Mac) must be sufficient, otherwise the transmitter automatically turns off. Turn up the volume on the Mac, and turn down the volume on the headphones. There is no way to disable the Automatic On/Off function of the transmitter.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Posted on Aug 12, 2011
  • 31 Answers
SOURCE: Hissing and poor sound quality
Well it could be interference from the TV, computer, or other 900Mhz device (some wireless routers run on this frequency).
I'm currently dealing with the same issue myself, if I find a solution I'll post back.
Posted on Mar 08, 2009
  • 7 Answers
SOURCE: Headphones gone quiet
Well, I think you've just blown them. I need more details...what music were you listening to? How loud? Etc.
Posted on Jul 27, 2011
While i am listening , every 5-10 minutes it starts tp bee[
With wireless headphones, a beeping signal most often means one of two things, a low battery or a bad signal. Please try the steps below to hopefully solve the beeping problem:
1. Turn off the headphones for a few seconds, then turn them back on while holding the button below the volume dial (look for signal button) for 5-10 seconds
2. If the above does not solve the beeping, then I would try to replace the batteries with either another set of NiMH rechargeable batteries or any other standard AA.
Hope this helps.
May 04, 2011 | Sennheiser HDR 130 Consumer Headphones
Low volume
1)Make sure volume is at maximum level. check down right hand side of your desktop. 2)Make sure speakers(headphones) volume is at maximum. 3) If problem continues check your speaker( connect it to other pc), and headphone as well. 4) If problem continues try reinstalling audio driver.
Mar 28, 2011 | Computers & Internet
I have bought a pair of Sony wireless MDR-RF810RK, and after five to ten minutes of listening ,the transmission fails and the light switches off. If I switch on again it recommences for some...
Hello!
I must inform you that most of the wireless headphones has an automatic shut-off which puts it in stand-by when there is no sound going in to it. Or if the sounds in your device is too quiet the headphones will think you have finished using it.
What you need to do is increase the volume setting of your device. And turn the volume control on the headphones down then as well - assuming that your headphone base unit is connected to the headphone socket of your device.
ALPUG
If this will help, please give this answer some ratings!
Feb 24, 2011 | Sony MDR-RF970RK Headphones
.cutting out and static
Hello!
ALPUG
Feb 20, 2011 | Hauppauge Wireless Headphones
Bluetooth headphones no longer working
Hi found the sulution by going through the forum all I had to do was start the transmitterby holding power down for 15sec then the light changed to a red blinking one then the samsung connected straight away thanks
Apr 22, 2008 | Samsung YP-T10 Digital Media Player
RCA Wireless headphone triggers off after 35 seconds of operation
ya the volume of your source is your issue.
if it is too low, the unit cuts out after 45 seconds or so...
crank up the volume and turn it down on your headset
Mar 16, 2008 | RCA WHP140 Consumer Headphones
Free Pulse
The following procedure will re-establish the communication link between the Headphones and the Wireless adapter, this is called "pairing". Before you start please make sure both the headphones and the wireless adapter are fully charged and turned off.
Note: The headphones and the wireless adapter come pre-paired from the factory.
1. Press and hold the power button on the headphones. See Figure 1.
Figure 1
2. Continue to hold the button down until the LED starts flashing red/blue in an alternating pattern. Release the button when the LED starts flashing red/blue. See Figure 2.
Figure 2
3. Once the headphones LED is flashing red/blue, press and hold the power button on the wireless adapter. See Figure 3.
Figure 3
4. Hold down the button until the LED starts flashing red/blue in an alternating patter. The LED will blink blue, then turn off for a few seconds then blink red/blue. Release the button when the LED starts flashing red/blue. See Figure 4.
Figure 4
5. Once both the headphones LED and the adapter LED is blinking red/blue, press the volume up button once on the headphones. See Figure 5.
Figure 5
Once the headphones is paired with the adapter, the LED on the headphones will blink blue once every two seconds. See Figure 6.
Figure 6
When the adapter is paired the LED will be solid blue. See Figure 7.
Figure 7
The adapter may continue to blink red/blue for a few seconds even after the headphones LED starting blinking blue. This is normal; the adapter may take a few additional seconds before the LED turn solid blue.
Once the headphones and the adapter are paired, it is not necessary to pair them again even if the batteries on both units are completely drained.
Additional Note: Repeated pairing will not improve the sound quality or give the headphones and the adapter a cleaner connection.
Mar 11, 2008 | Logitech FreePulse Wireless Consumer...
The sound just stops dead
I have the exact same problem. Try to crank up the volume from your stereo/receiver and lower the volume in the headphones. I think that the headphones goes into standby mode if the volume is to low. Works for me (for two days, so its not really a fact yet ;-) )
Feb 24, 2008 | Sony MDR-RF970RK Headphones
Intermitant transmitting
check the TV volume. it must be 50 percent or better or the headphones will stop working after about 5 minutes.
Jan 26, 2008 | RCA WHP141 Consumer Headphones
Volume with Headphones
The unit probably has resistors or a limitor curcuit to limit the amount of audiop going out on the headphones. It could probably be modifyed but it would possiblt burn out the headphones as this is a 280watt peak power unit . Its there so you dont blow out your ears.you could use some wireless self powered headphones as that would solve your problem!! Good Luck
May 12, 2006 | Philips FWC788 CD Shelf System
Sennheiser RS 110 Consumer Headphones Logo
75 people viewed this question
Top Sennheiser Audio Players & Recorders Experts
Michial Gueffroy
Steve Allison
Steve Allison
Are you a Sennheiser Audio Player and Recorder Expert? Answer questions, earn points and help others
