Getting card foramtting message when ON the camera Cybershot w310 can anybody help to fix this issue.thanks
SOURCE: Format Error in Sony Cybershot
i think this problem arises when you fail to regularly format the card ie. take lots of pictures and delete some and repeat the process over and over instead of downloading every session and formatting the card causing coruption. Also if you've bought pro duo memory stick off ebay poss. its a very good forgery (again i've been caught out by this).
there is no tools feature on the sony...select the 1st button lower right...all touch screen features appear...select menu in lower
left...select setup...camera 1 will display...select down arrow
twice until you reach format, the select...that should reformat
the memory...
SOURCE: format error on my sony cybershot dsc-s730
Format error comes because memory stick has an error. Please format memory stick by going in to Menu>> format>>OK
If error still comes then memory stick is bad and need to be replaced with new one.
SOURCE: Stuck power button on my Sony cybershot dsc-s600
Hi!
Yes, power buttons do break on these cameras. Contact your local Sony service center and see how much will it cost to replace the top panel. If they ask too much, feel free to contact me at [email protected]
I work in a Sony service center.
Tom
SOURCE: sony Cybershot DSC-W150,screen reads turn power on and off again
You may not believe this and I hope you haven't spent a lot of money fixing your problem. I read that some people had a different error message coming up on their Sony Cybershot DSC-W150's and in order to fix it, they literally banged the lens against their knee while the lens was out and it re-focused and the error message disappeared. I tried this while my camera was doing exactly what you described above AND IT WORKED!!!!!!!!!!!!!!!!!!!!
After 2 or 3 firm blows, my LCD screen came up and focused. I can't believe it myself, but I was just desperate enough to try it and VOILA!
Good luck!!
Here is a tip that I wrote
about SD Cards and how to unlock and lock SD Cards.
If you are getting a memory
card locked message then check
this out.
How
to Unlock SD Card
heatman101
