Question about NRS Hoveround MPV 5 - Used Power Wheelchair
Red light flashing on joystick about 10 min after charging
Wheelchair is placed on charger at night. In morning, charger shows green, ride wheel chair for 10-15 min and red flashing light on controller shows need charging again. New batteries and controller 6 months ago. Any suggestions on what to look for. also fuses checked.
    Master:
  • NRS Master
  • 401 Answers
Most of the time it may be the batteries at fault. One more thing to try is charging the chair with the Joystick on all night 10-14 hours uninterrupted charging. Your chair may suffer from current roll back. There is a circuit in your system that has to be reset by the long charge cycle to reset it. I did not make this up. it occurs when the motors over heat or have a a large current draw. the chair will operate normally for ten maybe even twenty mins. then suddenly drop down to 2 flashing red lights.
I’m happy to assist further over the phone at https://www.6ya.com/expert/bill_bcbb89783b08c489
Posted on Jun 01, 2016
6ya staff
SOURCE:
Anonymous
  • 4 Answers
SOURCE: Hooveround MPV won't move
Most likely either one or both of the batteries have a dead cell. Have your batteries load tested to check their condition.
Posted on Aug 13, 2009
Anonymous
SOURCE: Hoveround MPV4
Problem solved.
Posted on Dec 12, 2009
lennieg2000
  • 692 Answers
SOURCE: CHAIR BEEN SITTING FOR A
Ed After a year the batteries are shot and the charger cannot revive them Sorry but you're gonna have to spring for 2 new U1 batteries. Hope this helps you
Posted on Sep 21, 2010
HoverTech
Donna Angelo
  • 232 Answers
SOURCE: How do I charge the Hoveround mpv 4? I plugged the
Firstly, it is bad news to use an extension cord with the charger as it can get very hot. It will sometimes take 8-12 hours to get a full charge on the batteries. If the light does not go to green on the charger, the batteries may be damaged and not able to take a charge. This is especially true if the Power chair was stored after your father in law died; the gel in the batteries may have gone solid. The lights on the controller will go left to right then back if the charger is connected properly.
The brake release knobs both need to be in the UP/DRIVE position for the motors to engage.
Posted on Oct 01, 2010
HoverTech
Donna Angelo
  • 232 Answers
SOURCE: The chair won't power on and the batteries won't
After you changed the batteries, did the power chair sit unused for several weeks? It sounds more like a battery or fuse issue than a charger issue. If there are blinking lights when you try to turn the power chair on (not while attached to the charger), or it comes on then goes back off by itself quickly, there may be something else going on.
1- The green light on the charger is telling you that the batteries are not accepting any more power, either they are fully charged or they have oxidized/gone solid from sitting without being put on the charger for too long.
2-The scrolling lights on the controller when the charger is plugged in just confirms that the chair is connected to the charger, so it sounds like everything is connected properly and working. The horn will work fine when it is attached to the charger as it is getting power from the wall outlet.
3- If it was a fuse issue, the lights would not come on at all when the charger is NOT attached, even after the battery has been fully charged, which is what it sounds like is going on. The fuses can blow if you operate the chair on a slick surface or one of the drive tires spin out. The batteries will be fully charged but because the circuit is not complete, the chair will not power on.
I recommend checking the fuses and changing them if necessary. You are in luck because this is a relatively easy and inexpensive fix as they are standard automotive fuses found at any auto parts store or even Walmart for around $2 each (you need 2). The fuses are located inside the gray battery covers under the seat, attached to the leads connected to the battery cables. The straps holding the covers on the batteries are tight, you may want to use a flat head screwdriver to help release the clips. While you are down there, inspect the tread on the tires, if it is worn or slick it may need to be replaced for safety.
I hope this information is helpful to you- good luck!
Posted on Dec 27, 2010
When plugged into charger both lights show green but chair not fully charged
First measure the voltage of the batteries at the charging socket of the joystick.
Sep 28, 2014 | Pride Jazzy Select Elite
I have replaced joystick, batteries, motors and the chair still losing lights will go about 1/4 mile and loses all green lights with in 1/2 mile loses all the yellow lights, drove on 1 flashing light for...
Janice check your charger it could not be charging the batteries. Now always charge your batteries overnight while you sleep When you get up lights on the charger should be red and green if they are red and yellow then the charger hasn't fully charged the batteries and overnight should be more than enough time to charge fully. This could indicate a bad battery remember new doesn't always mean good. Like they say always charge before use and this goes for new batteries too you need to charge new batteries nightly for 10-15 days before they start operating at 100%. If when you plug in the charger before bed and the lights are red and green then there is a problem with the charger or the batteries or the charger circuit Hope this helps you
May 23, 2011 | Spirit Activecare /wildcat Foldable Power...
I have aenigma wheel chair with a shark contoller when you switch it on all lights come on then only one left hand light flashes red thanks Stuart
Stuart iy\ts indicating low battery voltage charge the batteries and see if it goes away if it doesn't then the batteries need replacing or your charge is not working correctly If after charging overnite when you get up in the morning the charger should have a green light on and the battery level should be full. If after just a bit it goes to the red flashing light then your batteries are bad and need replacing. If the chair is less than 6 months old then the batteries are under warranty and your provider(where you got your chair) must replace them at no cost Hope this helps
Mar 20, 2011 | Ctm HS-2800 Power Wheelchair
Do not know if chair is taking a charge lights just keep moving across armrest .how do u tell when fully charged?
hi let me see if i can help ,
When the lights go back and forth on your joystick that means the chair knows its pluged in .Now the chair itself has a built in charger that is mounted on the back of your chair .The back of the chair ,there is a opening a cutout in the frame .when you plug in your chair there will be a red light and a yellow ,yellow means the chair is charging, wait till it turns green,this means fully charged.When you plug in the chair youll see the lights through that hole.Look for the lights.
I recommend my customers to leave there chair charging over night look at the light it will be green when you turn the chair on the joystick should show fully charge.
Good luck hope i was of some help.
Jan 20, 2011 | Invacare Supply Group Invacare Pronto M51...
When I plug it in to charge the red and amber lights stay lit and the green flashes and if i move the joystick everything is backwards push forward goes backwards left is right. b4 when it was plugged in...
sounds like a charger inhibit problem. Whenever you charge your chair the charger inhibit shuts down the chair so it can't be moved while charging. If you are getting this then that function is not working. Lets try this if you know of someone who has a chair or scooter with an off-board charger see if you can borrow it. Plug the off-board charger into the charger port located under the front of the joystick (don't have the on-board charger plugged in) and then turn the charger on. turn the chair's power on and you hopefully will see the lights blinking again indicating a charger plugged in (charger inhibit) the lights on the charger should be red and yellow (yellow turning green when fully charged) If you still get the problem with the off-board charger then your problem is in the controller or power module and this requires a new one. If Medicare paid for your chair you can call Repair Xpress @ 1-877-81-3733 or Roadrunner Mobility @ 1-800-467-2668 to have them fix it for you and bill Medicare for most of the repair costs. Hope this helps you
Oct 31, 2010 | Invacare Pronto M51 Power Wheelchair
I am loosing green lights on my joystick quantam 600 power chair what could be wrong
The green lights will gradually go away as your battery is being used, this is completely normal. You batteries should last for around 5-10 miles of use. If you find that your battery light falls into the red after only 2-3 hours of use and you have been charging the batteries every night for at least 8-10 hours, contact your manufacturer for service.
Oct 11, 2010 | Pride Mobility Products Quantum Jazzy 500...
How do i charge the battery
Carla Under the front bottom of the joystick you will see a charger port its a three pin port that accepts the plug from the charger. Always plug the charger into this port with the charger off or not plugged into the electircal socket. Then plug the charger into the electical socket or turn it on. You should see a red light and a yellow light on the charger. When the tellow light turns green the batteries are charged. You should get into the habit of charging the batteries each night if you use the chair daily. Just plug in the charger when you go to bed and turn it off when you get up. If you only use the chair a little then always store it fully charged and then charge it once a week if it hasn't been used. Hope this helps you
Sep 12, 2010 | Quickie Wheelchairs Quickie Aspire Power...
What is the proper way to charge the Pronto M51
Eduardo After using your chair and the battery level lights are down with yellow or red lights showing just plug the chair into the wall socket and let er rip. Now really after using your chair during the day and you are ready for bed just plug in the charger and let it charge over night. In the morning unplug the charger and you should be set for the day. If you don't use the chair everyday always put it up with a full charge and about once a week plug it in and let it charge overnight. Never leave the chair plugged in all the time and never leave it for more that 24 hours. The charger has two lights on it one red and one yellow or green that are hard to see because they are under the rear cover. When the chair is fully charged the yellow light turns green and you can unplug the charger and you should have a full charge. Hope this helps you
Sep 08, 2010 | Invacare Pronto M51 Power Wheelchair
How do I know when the chair has charged? I see one red, two green, two yellow lights on.
If you have an off-board charger that plugs into the joystick there are two lights on the charger one red(power on) and the other yellow (turns green when fully charged). Plug it into the chair and if the light is green then you have fully charged the batteries. Now if you have the on-board charger the charger meter on the rear of the chair will resd zero when fully charged. Hope this helps ya
Aug 18, 2010 | Electric Jazzy 1115 Power Wheelchair
When turning power it makes a clicking sound but does not power up. battery charger has a red and green light on. When plugged in and turned on it flashes 8 times. I checked the power control connection,...
The chair will not move if the charger is plugged in. The flashes are normal with the charger plugged into the chair. The lights on the charger mean that the batteries have been fully charged. Red and yellow lights mean charging. After you unplug the charger from the chair (if off-baord charger, turn charger off or unplug from the wall) then unplug from joystick. after plug is removed from joystick press the on button and all the battery lights should be lit and when you move the joystick forward you will hear the electric bake release and the chair should move forward etc Hope this helps
Aug 10, 2010 | Pride Jazzy Select 6 Indoor Power...
NRS Hoveround MPV 5 - Used Power Wheelchair Logo
383 people viewed this question
Top NRS Health & Beauty Experts
Vitally Alcher
Norman Worley
Are you a NRS Health and Beauty Expert? Answer questions, earn points and help others
