Bring a focal point to your kitchen by having an island range hood, combining function and elegant form. A suspended hood is also an efficient way to vent
grease, odors and smoke to the outside from a island stovetop while you cook. You can install an
island range hood in just a few hours with the right tools
and knowledge.
1.Wear safety glasses and work gloves. Turn off the electricity to your kitchen at the circuit panel. Cover the circuit breaker with a piece of electrical
tape to prevent people from turning the on switch while you are at work.
2.Lay work drop cloths on your cooktop and floor to catch dust and debris. Mark the duct opening with a pencil in the ceiling, where the island hood will be
installed. Be sure the opening is centered directly above your cooktop. Cut the opening using a hacksaw.
3.Go up to the roof, using a cat's claw and hammer to remove stucco, tiles, sheathing and insulation to make way for the steel venting duct. Drop a
plumb bob down the roof, making sure the line is straight down for the ductwork.
4.Follow the manufacturer's instructions for locations, installing 2-by-2 wooden blocks in the ceiling to hold the ductwork hangers.
5.Install the venting duct from the outside of the home, down to the location of the exhaust vents on the island hood. The ducts should easily slip into each
other. Secure all the duct sections with duct sealing putty, using a putty knife.
6.Screw a roof cap on the end of the duct at the roof. Seal any openings or gaps where the roof, ceiling and duct meet with silicon sealant. Let the sealant
dry, then paint with colors matched to the surrounds.
7.Place your hood upside-down on the floor, with the fan and filter facing upward. Locate and unscrew the metal electrical box cover on the island range
hood, to expose the wiring
8.Install the hood cover to the load-bearing ceiling frame with the package hardware through the four inside mounting corner flanges on the cover.
9.Measure what will be the distance from the bottom of your hood to the cooktop; it should not exceed 30 inches for exhaust efficiency. Have a helper hold
the hood in place while you attach the hood on the hood cover using the included screws. Use a level be sure the hood is level as mounted.
10.Connect the electrical wiring by consulting the manufacturer's suggestions or hire an electrician if you are not familiar with house wiring. Tuck the wires neatly in the hood electrical box and then replace the cover, after connecting the hood wires to the wall wiring.
11.Remove the electrical tape on the circuit breaker, turn on the electricity to your kitchen and test your island range hood.
Can it be fixed without taking the whole hood off the wall?
