1)I cannot format the pendrive. 2)when i double click on the removable disk,it says ''Please insert a disk into Drive E :'' 3)i used a pendrive format utility but the problem persists again. 4)i tried to format it using gnome also )I cannot format the pendrive. 2)when i double click on the removable disk,it says ''Please insert a disk into Drive E :'' 3)i used a pendrive format utility but the problem persists again. 4)i tried to format it using gnome also
Drive appear in manager and mycomputer but when i trying to open the pendrive error shows "please insert the disk in a drive E
First Method:
Turn off first your computer and then plut in your pen drive into usb port and turn on you pc.. if it's still not working try another method
Second Method:
Insert your pen drive on your usb port...
1.Right Click "My Computer"
2. Select Manage
3. Click Disk Management
4. Look for the Removable Drive Letter (which is your pen drive)
5. Right click on it...
6. Select "Change Drive Letter and Paths.."
7. Try to Change it on Letter T: W: X: Z:
8. Done
Hope this will help your problem
Ms. CompTech
in tha disk management it is not detecting so is there any solution
in disk management it is not decting my flash drive
Da drive does not apear on manager
Ipot MP3 showing on Plese insert adish into drive H
How to Get my data from my pendrive when it is in error please insert the disk into drive
SOURCE: sony 8 gbpen drive not formatted
can it be made to work on a win box? if it cannot then i suggest it may be fuct ! (failed under continuous testing)
same as above
same?
I am also facing the same problem.
not able to format and when i double click on the icon its saying please insert disk.
pls give solution........
same problem
same problem
help
i too have the same problem please help.
1)I cannot format the pendrive. 2)when i double click on theremovable disk,it says ''Please insert a disk into Drive E :'' 3)i useda pendrive format utility but the problem persists again. 4)i tried toformat it using gnome also)I cannot format the pendrive. 2)when i double click on the removabledisk,it says ''Please insert a disk into Drive E :'' 3)i used apendrive format utility but the problem persists again. 4)i tried toformat it using gnome also
same problem but in a kingston 8gb. Is it covered by waranty?
