Sunpentown SR-964TB Induction Cooktop Black Logo
TRACY BIEN Posted on Feb 18, 2013
Error code e7 - Sunpentown SR-964TB Induction Cooktop Black
Miele KM-493 induction stove. What does error E13 indicate?
  • Error code E13 error showing on display
  • What causes an E13, E 13 error code on the Induction Cooktop control panel?
  • Error code 13 on Induction Cooktop control panel
Cause:
  • Universal OFF key failure
Troubleshooting:
  1. If the controls are wet or water made contact with them, dry off the controls.
  2. Turn off then back on to reset.
  3. If the error persists, reset the unit at the circuit breaker.
  4. Turn the unit back on to see if the error code cleared.
Omega ceramic cooktop error code F
GOOGLE KNOWS check link below
https://www.google.com/search?q=Omega+ceramic+cooktop+error+code+F&oq=Omega+ceramic+cooktop+error+code+F&aqs=chrome..69i57&sourceid=chrome&ie=UTF-8
Apr 18, 2021 • Cooktops
What does error code E-13 mean
Hello there
Sounds like a 'gas sensor' (whatever that is) error. I recommend calling Samsung Support or a qualified Microwave Technician
SMH2117S/XAA Microwave Is Displaying An Error Code If your microwave is displaying an error code, such as -SE-, E-11, E-12, E-13, or E-14, or any other trouble code not listed here, cycle the power to the microwave by either unplugging the unit, or cycling the circuit breaker for approximately 60 seconds before restoring power.
If the above suggestion does not work,and the error code returns, your microwave will require service.
namo_fileview.jsp?type=nfs&pid=decisiontree&did=466719&cid=5uwnecasicas@namo.co.kr&sep=%7c
What is ge error code 0225
I have the same issue and was told by GE that it will take a technician to fix it because it is not a known error code. Most error codes start with "f", F0, F1, etc. This the second time a tech had to come out for this cooktop. Probably the last GE I buy. Definitely won't buy anything electronic. I want regular knobs on the next one.
Whirlpool error code e2 f3
The error codes are in the operating instructions if you don't have it ask Bosch to email the error code page to you.
E30ic80iss electrolux error 31
Good Morning D, I am happy to assist you. Error code E31, commonly refers to an internal generator error in the left side cooking zone and that the generator control board needs replacing. One of the best ways to determine if this is a false error code is to reset the power to the appliance by either unplugging it or flipping off the breaker for about 30 seconds. If the error code persists, I would recommend connecting with an experienced appliance repair tech to assist further.
11helpful
2answers
Recently i have purchased Prestige induction stove, can you describe what does E3 mean?
e 3 is error because of high voltage may be more than 30 kW at your house......it will not work with it u have to buy a voltage regulator for it........
Fault Code E7 is up after a small amount of time cooking. power needs to be reset a number of times before it will work again. What does it all mean
Hello there:
this E7 code is referring to a improper temperature between what the oven is set at and the actual temperature is .
So now knowing this you will have to have the temperature sensor or the thermostate repaired or replaced you can also try to unplug or trip the breaker for the appliance for 30 minutes then reapply the power to the unit , these units do have a self reset feature on it but if it doesent then have the appliance serviced by a qualified service repairman
ALSO if you have a warranty with this unit it may be covered with the warranty ok?
best regards Michael
Top Sunpentown Cooktops Experts
Paul Carew
ADMIN Andrew
ADMIN Andrew
Are you a Sunpentown Cooktop Expert? Answer questions, earn points and help others
