Our issue started with display not lighting up, we took out a fuse from the bottom of the control board and it busted. A tech came out to look at the treadmill and states we needed a new circuit board and we have been waiting on him to get for several months. He was suppose to have replaced the fuse and even charged us for a fuse, but we have recently taken the board off treadmill to see if we could find someone else to repair and found that he did not even put a fuse in it. We have purchased different amp fuses and once it is in the display lights up now when power is turn on. But when we start the motor the fuse blows. We have no way to know which fuse to buy to even find out if that is the only issue. Is there any way you may be able to help us with this?
SOURCE: F6 CODE ON A BLADEZ TREADMILL
please test the motor see my personal TIPS for motor help. However this is indication, controller failure. see the block diagram too.
Testimonial: "WHERE DO I FIND YOUR PERSONAL TIPS FOR TESTING THE MOTOR,,,, THE DRIVE MOTOR WORKS FOR ABOUT 2 TO 3 SECONDS THEN SHUTSDOWN UNDER A E6 CODE, I SUSPECT THE ELEVATION MOTOR OR SETTINGS IS OFF"
