Sharp EL-531VB Calculator Logo
Posted on Feb 13, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Seconds into hour minute second
How do you convert let say 20000 seconds into hours minutes seconds with a scientific calculator? which key does the job?
JP
k24674
Level 3:
  • Sharp Master 8,093 Answers
  • Posted on Sep 20, 2009
k24674
Sharp Master
Level 3:
Answers
8093
Questions
0
Helped
4675084
Points
21596
Use the witeView Mode or fraction mode
20000s /3600s/h gives 5 full hours, remain 2000 seconds,
2000s/60s/h gives 33 minutes remain 20 seconds.
Result is 5h 33 min 20 sec
Do not confuse the DMS degree, minute, seconds with th hour minute seconds.
Hope it helps.
  • k24674 Sep 20, 2009
    There is no key for this type of calculations.
  • k24674 Sep 22, 2009
    Sorry 2000/60s/min gives 33 minutes remain 20 s
Hp 32sII enter degrees minutes seconds
According to the "HP 32SII RPN Scientific Calculator Owner's Manual" (at the link below), you just need to treat degrees, minutes, and seconds conversions as hours, minutes, and seconds. Use the left-shift and right-shift keys together with the 5 key to convert to decimal-fraction form (D.d format) and to minutes-seconds form (DD.MMSSss), respectively.
http://www.hp.com/ctg/Manual/bpia5305.pdf
See pages 4-9 and 4-10.
hp-32sii-enter-degrees-minutes-seconds-5ti10bsvdnjq4loa1azfxjeu-1-0.jpg hp-32sii-enter-degrees-minutes-seconds-5ti10bsvdnjq4loa1azfxjeu-1-1.jpg
10helpful
How can i convert degrees,minutes and seconds to decimal degrees in a casio fx-82MS
Use the DMS key marked degree, apostrophe, double quotation mark.
Lets us call it [DMS]
To enter an angle in degree minutes seconds or hour, minutes, seconds, type in the number of degrees, press the [DMS] key, enter the number of seconds, press the [DMS] key, enter the number of seconds then the [DMS] key. Press = the calculator displays the value in DMS units. If you press the DMS key again the number displayed is converted to decimal degrees.
Example:enter 12 degrees, 15 minutes, and 25 seconds
12 [DMS]15[DMS]25[DMS] =
Calculator displays 12 deg 15'25"
Press the DMS key again and you see 12.2569444
1helpful
Dd to dms conversion
Press the DMS button to convert between decimal degrees and degrees-minutes-seconds.
The DMS button is marked with the degree, minute, and second symbols. It's located above the [ENG] key, which is located above the [8] key.
For full details, start with the "Degree, Minute, Second (Sexagesimal) Calculations" section beginning on page E-22 of the manual. If you need a manual, you may download a copy here.
Meter to kilometer
There are 1000 meters in a kilometer and 3600 seconds in an hour (60 seconds per minute, 60 minutes per hour).
Press 8 0 0 / 5 0 * 3 6 0 0 / 1 0 0 0 =
or 8 0 0 / 1 0 0 0 * 3 6 0 0 / 5 0 =
The result should be 57.6 kph.
5helpful
Can I convert Decimal Degrees to Degrees, Minutes, Seconds on my casio fx-991 ES?
Yes. Pressing the DMS key (two keys above the 8 key) when a result is displayed toggles the result between decimal degrees and degrees-minutes-seconds.
For example, to convert 3.5 degrees, press 3 . 5 = and you'll see 3.5. Now press DMS and you'll see 3 degrees 30 minutes 0 seconds.
2.45.35 hours - 0.23. 12 hours = ?. a short quick method please
Seconds: Subtract 12 from 35 to get 23.
Minutes: Subtract 23 from 45 to get 22
Hours: Subtract 0 from 2 to get 2.
Put the three together to get 2.22.23
This one was easy because there was no need for carry. If you do have to carry, just make sure you carry 60. Otherwise, it's exactly the same as when you learned subtraction in second grade.
Some calculators have conversions between decimal degrees/hours and degrees/hours:minutes:seconds. If you have such a calculator, you can convert both numbers to decimal, subtract, and convert back. Since you didn't specify what calculator you have, I can't tell whether this is an option for you.
3helpful
How do you find degree minute seconds on calculator
To convert a decimal degree value to degree-minute-second, press the o'" key just above the ENG key.
3helpful
How do i convert a degrees/minutes/second problem using the Casio Fx-115ES calculator? Can you provide an example? Thanks ZH
Use the key above the ENG key to enter a value in DMS form, ending each portion with the key. To convert it to decimal, press SD once (or twice if you get a fraction the first time).
Example: sine of 12 degrees 15 minutes:
sin 12 *** 15 *** =
where *** is the DMS key.
An ant carries food at a speed of 1 cm/s. How long will it take the ant to carry a cookie crumb from the kitchen table to the ant hill, a distance of 50 m? Express your answer in seconds, minutes and...
Since there are by definition 100 cm in a meter, the distance is 50x100 or 5000 cm. At 1cm/s it takes the ant 5000 seconds to cover the distance. There are 60 seconds in a minute, so it takes 83 minutes and 20 seconds.
NO PROBLEM. JUST TRYING TO UNDERSTAND THE
Here is instruction from the user's manual. the manual link is below, for downloading:
TIME CALCULATION KEY:
• Utilise this key to enter hours and minutes in time
calculations.
• Press this key after entering an hour or minute value.
(There is no need to press this key when entering a second
value.)
• To bypass hour entry, press this key after entering 0.
• To bypass minute entry, you may press this key alone, or
press it after entering 0.
• When this key is pressed, if the preceding entry is in any of
the following ranges, it is set as an hour or minute value:
Hour: Within 6 digits
Minute: 0 to 99 (An entry above 60 is rounded up to one
hour. If a value of more than 3 digits is entered,
only the least significant two digits take effect.)
• A second value is set when it is entered in the following
range:
Second: 0 to 99 (An entry above 60 is rounded up to one
minute. If a value of more than 3 digits is
entered, only the least significant two digits take
effect.)
http://www.sharpusa.com/files/cal_man_EL1197PIII.pdf
Top Sharp Office Equipment & Supplies Experts
k24674
ZJ Limited
ZJ Limited
Norman Weimar
Norman Weimar
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
