We have a partial wall behind our range, and when we place the mounting template under the cabinets, the template hangs about 6" below the wall.....there is nothing but air where we are supposed to place the mounting bracket. Can we Move The mounting bracket up? Do I have to extend the wall down? Any ideas.
SOURCE: Microwave installation under cabinet, no rear wall
Hi , I would like to suggest to visit near appliance center to purchase hanging for oven . ace hardwares.
Your model weighs 41 pounds empty.
That - plus maybe adding another 8-10 pounds for safety - us what your installation needs to be able to handle.
I would think the average cabinet could handle that, but it may be better to add a small steel plate or large washer surrounding the mounting screws to help disperse the weight load.
The owner's manual describes the installation kit you can use to mount it in a cabinet or in the wall, etc. That may be helpful.
If you don't still have your manual you can download it here.
We're happy to help and we appreciate your thoughtful rating of our answer.
SOURCE: peninsula otr microwave installation
I cannot comment on this. On something that is non-standard and specifically warned against in the manual, I would only comment if I were there to inspect it.
I would get a pro's on-site opionion.
SOURCE: One stud in the middle for an OTR Microwave Install?
i had the same trouble, yes i used a solid bolt to hold the microwave bracket in the stud then used the biggest toggle bolts that will fit, also the cabinet will not have to be changed. it works fine, if you had a vent a hood dont forget to hook up the exhaust vent. i figure your old exhaust vent is in the cabinet like mine was
SOURCE: How do I remove Frigidaire FMV156DCC under cabinet microwave?
Underneath the microwave, on the right & left hand corner sides at the back, there are levers that you pull down & it releases the mounting bracket.
