Hi. This is a Kirby Vacuum model G7D. The Ultimate G series. Have problem with Neutral/ Drive lever on back. Very difficult to operate, very stiff and sometimes impossible to change gears. Torx head screws! Used to be it all came apart easy breezy, my Mother fixed everything on hers for a 100 years as it was originally designed. Thanks
Manual on how to do it - take a look HERE ENJOY
SOURCE: gear lever
here are a few links to repair proceedures for the kirby (pictures included)
Transmission:
http://www.greatvacs.com/Kirby%20Transmission%20Adj.shtml
On/Off switch
http://www.greatvacs.com/Kirby%20Powerswitch.shtml
Hope that helps!
SOURCE: Manual
http://geeksquad.fixya.com/ThreadView.aspx?prdid=11557&thid=617575
Manual
Posted by Caroyl on May 23, 2008
Is there a manual I can download online for the
Kirby Ultimate G Series Diamond Edition, Model G7D?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. My suggestion is that you contact the Kirby Co in Cleveland listed below and they will instruct you either to down load a owner’s manual or they will mail one out to you, there might be a local Kirby dealer in your area that might have a manual as well. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://kirby.com/ Customer Service – United States & Canada 1-800-494-8586
Hours 8:00 am to 5:00 pm (EST) U.S. & Canada Fax # 1 (216) 529-6146
Mail To:
Consumer Relations
The Kirby Company
1920 West 114 Street
Cleveland, OH 44102
Thanks, Don the Vac Man
Go Ahead. Use Us.
SOURCE: i have a kirby ultimate
Ouch...
You need new pedal assembly. Just Google 558401S . I saw one for $16.10.
You can try to fix it just you would have to install it back at a certain angle. clean shaft very well with alcohol so it is completely grease free and use a drop of superglue. However this is not likely to hold for longer period of time.
Good Luck
SOURCE: Green light on power nozzle of Kirby vacuum, Model G7D
The green light is just to inform you that the brushroll is spinning. there is a magnet on the brushroll that makes the green light come on every time it rotates. also why it looks like the light flickers because the magnet only makes contact once per rotation of your brushroll. Let me know if you have any other questions.
