Computers & Internet Logo
Anonymous Posted on Feb 17, 2013
Can't reset windows 7 logon password as error
Anonymous
Level 1:
New Friend:
  • Contributor 3 Answers
  • Posted on Feb 17, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
166
Points
9
Try this :
  1. Download the Reset Windows Password utility onto an alternative computer. Unzip the download file, you'll get the ResetWindowsPwd.iso file. Burn the ISO file to CD using an CD burning software such as ISO2Disc orBurnCDCC.
  2. Set your Windows 7 laptop to boot from the Live CD. To boot from the CD-ROM drive, you may need to press a key such as F8 or F12 while your computer is starting up and set CD/DVD as the first boot device in BIOS.
  3. After the CD boots, you will have a mini operating system loaded into memory which will launch Reset Windows Password utility. It will not install anything to your hard drive.
  4. Click on the Reset Windows Local Admin/User Password option, the program will automatically detect the Windows SAM registry hive and local user accounts existing in your local computer.
  5. Choose the administrator account and click on Reset Password button, it will remove your forgotten Windows 7 administrator password in a short time.
3 Related Answers
Anonymous
  • 2246 Answers
  • Posted on Jan 04, 2011
SOURCE: wont letme get in main menu says this feature
check your hard drive connetor, is your hard drive connected properly
Anonymous
  • 859 Answers
  • Posted on Oct 31, 2008
SOURCE: Logon problem with Compaq notebook!
You're welcome, you can rate this now. Good Luck.
Anonymous
  • 123 Answers
  • Posted on Jan 28, 2008
SOURCE: Resetting Admin password
go to setup>and go to maintanance -->there is a option restore default>select that and after some time do power cycle>and rste me solved if its helps
or
go to your user accouny and change your password
2answers
I changed my username now my password won't work this is on another computer.It ia a dell windows 7.It don't have a place for a disk
Go to the link below and download Ophcrack and burn the iso to a bootable USB Pen Drive... Boot from the bootable USB Pen Drive and let it do it's magic. You'll have the password shorthly:
http://ophcrack.sourceforge.net/download.php
tip
Lost Acer Windows 7 Logon Password?
The netbook is redefined with the arrival of the Acer Aspire computer and many people like it. Most of them intall Windows 7 Operation System. As you know, a logon password should be created to protect your Windows 7 user account. Sometimes, you <b><a href="http://www.windowspasswordsrecovery.com/forgot-windows-7-password.htm">lost Windows 7 logon password</a></b>, how to reset it on your Aspire laptop? E.g. <b>Acer Aspire One</b><a href="http://www.windowspasswordsrecovery.com/images/knowledge/lost-acer-windows7-password/acer-aspire-reset-windows7-logon-password-big.jpg"><img src="acer-aspire-reset-windows7-logon-password.jpg" /></a> <br /> <b>Notes:</b> <br /> <b>1.</b> If you don't have created a password on Acer netbook, you may be insterested in this tutorial: " <a href="http://www.windowspasswordsrecovery.com/create-a-windows-7-logon-password.htm">How to Create A Windows 7 Logon Password?</a>"<br /> <b>2.</b> If you forgot Windows 7 User password, you have 2 methods to retrieve it. One is below steps, another is this guide: " <a href="http://www.windowspasswordsrecovery.com/reset-windows-7-password.htm">Reset Windows 7 Password With a Password Reset disk that was created before you forgot Password</a> "<br /> About Acer Aspire Aspire is a series of personal computers by Acer Inc. aimed at the casual household user or for small business use. The Aspire series covers both desktop computers and laptops. Acer developed the series in order to cover from essentials to high performances.<br /> How to Reset Windows 7 Password on Acer Aspire? Just follow below steps to recover your Acer PC password, it will only take your few minutes.<br /> <b>1.</b> Login another computer that you have access, download <a href="http://www.windowspasswordsrecovery.com/downloads/Windows_Password_Recovery_Tool_Pro_Trial.exe"><b>Windows Password Recovery Tool Professional</b></a>, install and run it.<br /> <b>2.</b> Burn a Aspire laptop password reset disk, you can use CD/DVD or USB Flash Drive. I recommend USB if the locked Aspire laptop supports it.<br /> <b>3.</b> Connect the password reset disk with the locked Acer computer, Press "Del" while the computer just start, then <a href="http://www.windowspasswordsrecovery.com/getting_started/bios_usb.htm">go to bios setting to boot computer from the USB Flash Drive</a>, reboot the computer to load the program. <br /> <b>4.</b> Select the user account which you lost itslogon password, click "reset" button to begin resetting password.<br /> <b>5.</b> A message box will pop up, just click "Yes", then the user's password will be hacked.<br /> <b>6.</b> Disconnect the password reset disk, and reboot Acer PC. You will login Windows 7 without password.<br /> Screenshots on resetting Aspire Computer Password <a href="http://www.windowspasswordsrecovery.com/images/knowledge/lost-acer-windows7-password/burn-aspire-laptop-password-reset-disk-big.png"><img src="burn-aspire-laptop-password-reset-disk.png" /></a> <a href="http://www.windowspasswordsrecovery.com/images/knowledge/lost-acer-windows7-password/reset-lost-acer-windows7-password-big.png"><img src="reset-lost-acer-windows7-password.png" /></a><br /> Finally <b>Acer Windows 7 Password Recovery</b> is not a difficult thing, you don't need to become a expert. Above experiment was carried out under Windows 7, but this tool also supports Windows XP, Vista, 2008, 2003, 2000.<br /> Tips: <b>1.</b> You can <b><a href="http://www.windowspasswordsrecovery.com/create-windows-7-password-reset-disk.htm">create a Aspire Password Reset disk</a></b> before your lost Windows 7 Account password.<br /> <b>2.</b> Keep in mind that this software can be only used on your own computer, never try to use it to hack other person's login password without permission. Otherwise, you will be caught by police.<br />
on May 23, 2011 • Computers & Internet
To reset password on windows 7
Have you lost windows 7 password?
Now, we'd recommend you a professional Windows password recovery software- Windows Password Reset as your reference.
As an easy method to reset Windows 7 password , there are only four steps as follow:
Step1: Download Windows Password Reset Deluxe and install it.
Step2: Burn the ISO image file onto a USB flash drive.
Step3: Boot up your Windows 7 PC by the bootable burned USB in minutes.
Step4: Remove the forgot Windows 7 password on the operation interface and logon PC without password.
How to bypass admin passwords on windows 7
Now, we'd recommend you a professional Windows password recovery software- Windows Password Reset Deluxe as your reference.
Step4: Remove Windows 7 password on the operation interface and logon PC without password.
4helpful
9answers
I forgot my administrative password, whenever i turn on my compaq 6220 notebook it displays Power on Password. Please what can I do to remove it.
You can remove the admin password of your locked computer then you can logon as administrator.
A useful tool just like Windows Password Rescuer can perfectly solve this problem.You also can use it to create a new administrator account without login then you can logon directly with the new account.
If your system is Windows 7/vista/xp,you can use "Windows Password Rescuer Personal/Professional'.
If your system is Windows 2008/2003/2000,you can choose "Windows Password Rescuer Advanced".
4helpful
9answers
I have forgotten my password for my acer aspire one and i cannot get onto my brand new laptop! because of the windows 7 please help!
I recommend software Windows Password Seeker. Not only support XP/Vista/2000/NT, but also compatible with windows 7, it works perfectly to remove Windows login password. I wrote it to a USB flash drive. Booting up and clearing my password within 4 minutes. You can download it from:http://www.passwordseeker.com
3helpful
5answers
I just bought an acer aspire one 10.1 netbook with windows 7 . I set it up with a password and can not for the life of me sign on now. I am entering the password I think it is but no luck. when I click...
Lost Acer Windows 7 Logon Password? ' How to reset Acer Aspire One password if you don't know it?
  • The netbook is redefined with the arrival of the Acer Aspire computer and many people like it. Sometimes, you lost Windows 7 logon password, how to reset it on your Aspire laptop?
9helpful
15answers
Remove password password
Reset Administrator Password ' Free and Fast Methods to Reset Administrator Password
Are you looking for ways to reset administrator password? Do you believe there are several free and also fast methods to administrator password reset? Windows Password Recovery Tool can release all your doubts!
4answers
WINDOWS LOGON PASSWORD RESET
If you can log in to the system, you can go to user accounts in control panel and change the password.
If you can't you can try steps here
http://www.fixya.com/support/r3743393-ve_lost_or_forgotten_windows_password
24helpful
8answers
Forgot password to hp laptop how do i reset it.
I don't know what OS your HP laptop is installed with.
If it is Windows 8, Windows Password Hint, PIN code, Microsoft account can be used to login HP laptop. After logon successfully, change, recover or reset Windows 8 password is available.
If it is Windows 7, Password hint or another administrator account may help you. But if you don't have all of these, try password reset disk. Create it before Windows 8 locked or with Windows 8 Password Recovery tool is OK.
Besides these, Chntpw USB disk also works for Windows 7/Vista etc.
Grand Canyon Tech
Grand Canyon Tech
