Heavy Machinery Logo
Posted on Feb 13, 2009
Briggs and Stratton fuel flow/vacuum fuel pump
I own a Briggs and Stratton 8 hp horizontal shaft IC engine on my Troybilt Tomahawk chipper shredder and have a fuel flow to the float bowl problem. The engine is difficult to start. I typically run the float bowl dry at the end of the season. If I don't, the float bowl is typically empty after a few months anyway. At the homeowner level, I have worked on small engines before and somewhat familiar with small engines. However, I have never owned an engine that had a vacuum operated fuel pump. I assume that Briggs uses one when part of the fuel tank (based on the engine configuration) is below the float bowl and needs the pump to maintain fuel in the pump. I don't know if this is the case; just an observation. So I figured if I fill the tank, fuel will flow by gravity to fill the bowl and the engine will start. Not the case. I disconnected the fuel line between the pump and float bowl, opened the shutoff valve between the tank and pump and there was no gravity flow to the float bowl. Flow only occurs when the recoil is pulled and only in small spurts. It seems that it takes maybe 20 to30 pulls on the recoil before the engine starts (ie: the bowl is full). Is this typical? Or should there be free gravity flow to the bowl through the pump when the tank is full? Or is the pump faulty and should provide enough fuel to fill the bowl in maybe 3 pulls? I don't want to run out for a new pump if that isn't the problem.
Thanks.
Glenn
  • 4 more comments
  • gpcharnie Feb 13, 2009
    The engine is an 8hp IP (Industrial Plus), Model 196432, Type 0121-01, Code 9409191B. Thanks for the question. I thought the problem was of a more general nature.
    Thanks.
    mrfixit-jerr,
    I initially thought that the hard starting was due to a dirty carb. I sprayed cleaner in the orifices and blew them clear. I may not have gotten to all of them but if I didn't, a clean carb seems to be a secondary issue. The units starts fine from day to day. It is when I start with an empty float bowl. When I disconnect after the pump, there is no flow to fill the bowl unless I pull the recoil; and then it is only in small spurts. If I disconnect the fuel line before the pump, the flow is fine and there is no restriction of the fuel TO the pump. My hard starting is due to the float bowl only filling when I pull the recoil and it fills in spurts (which is typically 20 to 30 pulls). Is my float bowl filling properly which is that there is only flow to the bowl when the machine is rotating (either by recoil or when the engine is running) even with a filled fuel tank?
    Thanks again.
  • gpcharnie Feb 14, 2009
    mrfixit-jerr,
    The fuel pump is attached to the engine and not the carb. It isn't very large; maybe 1" x 1.5" x 5/8". I will check the vacuum line; that is a good recommendation and a cheap fix. I checked out the price of the pump and it is only about $18. It is a throwaway pump and cannot be repaired. In the meantime, I contacted a briggs dealer who I found on the net as "willing to provide friendly advice". I was told that the system operates as I described. He recommended that I not run the bowl dry at the end of the season as I sometimes do. This way the bowl will always have available fuel for immediate starting. I was afraid of that. But the pump may not be operating satisfactory since it takes 20 to 30 pulls on the recoil to fill the bowl; thus your recommendation on checking the fuel line is well taken. I may look into it further and just order a new pump to put it to rest in my mind.
    Thanks for your helpful advice. Well appreciated.
  • gpcharnie Mar 11, 2009
    I don't quite know what a 'hand squeeze primer bulb' is for this application. Could you explain? Upstream or (I assume) downstream of the fuel pump? I guess you realize that 'two or three squeezes' will have to fill the float bowl from empty which may be 1/8 cup to 1/4 cup of fuel. Unless, of course, I misunderstand what you are saying.
    It would be great if I could install a typical Tecumseh type primer bulb which primes the carb throat and let the engine kick to get the pump filling the float bowl. Maybe two or three of these would fill the float bowl and then allow the engine to start.
    I certainly appreciate anything else you may recommend.
    Thanks.
  • Anonymous May 11, 2010
    hello me g,if you give me the model and type number i could give you a perfect answer,ok.
  • Keith marshall
    Keith marshall Sep 02, 2018
    If it is a vacuum pump there would be little gravity flow the pump diaphragm is bad or your tank is blocked somewhere
Anonymous
Level 1:
  • Contributor 3 Answers
  • Posted on Mar 11, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
18285
Points
A quick and simple fix is to place a hand squeeze primer bulb between the fule tank and the engine.
before attempting to start the engine. give it 2 or 3 squeezes to prime the float bowl. then start the engine like normal.
  • Anonymous Mar 12, 2009
    you can get the hand squeeze primer bulb at a local auto parts store... they are normally 2.5" around and just slightly longer than the palm of your hand is wide... get the one that fits your fuel tank supply hose, this is somewhat like a syphine(ms) primer ... it roughly looks like a center fattened hot dog....with hose connectors at each end.
    usually 3 to 4 squeezes max is enough to fill the carb bowl. I use one on a pump motor which is a 10 hr Briggs engine. and 3 squeezes works for me. my fuel tank is a 5 gal. army gas can sitting 2 feet from the motor in an even level with it... so once the engine is started and running the vaccuum from the pistons draw the fuel at an even draw....
    hopes that helps... when asking for that item at the auto parts... ask for a fuel primer squeeze bulb.(in line style)
    Tecpro
2 Related Answers
Anonymous
  • 3 Answers
  • Posted on May 02, 2009
SOURCE: looking for manual for troy-Bilt super tomahawk wood chipper
I have the both the manual and parts catalog for Troy-Built 8hp Tomahawk, can send them to you for the cost of coping and postage if you haven't found them yet.
Ron Bowman, [email protected]
Anthony Browning
  • 640 Answers
  • Posted on Sep 19, 2011
SOURCE: I have a Troybilt tomahawk
You should be able to get the chipper's model number off the tag or label. With that model number you can go to the local small engine repair and parts shop to get the replacement pulley or you can look online at Troybilt and using the model number look up the drawings for the chipper and select the correct part and order it from them. Partstree.com and outdoordistribut
8 HP super tomahawk chipper/shredder model 10941 purchased 1986 need belt. old number W5L290. anyone know what will work, and fit the V grove right?
you can get guides online for error codes/ fault codes, wiring diagrams, schematic diagrams , torque specs, engine info, switches functioning, assemble, disassembly, complete refurbish, repair, installation every single thing is covered
within seconds u can get the access and it's totally illustrative complete
I know these websites
Looking for a manual for troy bilt tomahawk chipper shredder, model #47255
you can get guides online for error codes/ fault codes, wiring diagrams, schematic diagrams, torque specs, engine info, switches functioning, assemble, disassembly, complete refurbish, repair, installation every single thing is covered
1helpful
I have a Troybilt tomahawk chipper. The bearings in the belt tensioner pulley have failed. It is a sealed bearing-- so not easy to replace. Do you sell the whole pulley? -- or what to you recommend?
I need a parts and owners manuel for a Super Tomahak Wood chipper made by Garden Way Mfg. Co. where do I go to get one?
Hi and welcome to FixYa. I am Kelly.
Go to this site:
http://www.brentchalmers.com/
I note your looking for the Super Tomahawk. If you can come up with a model number I think I can find your parts manual for sure. (or at least an on-line parts list.) Also.... If you can come up with an engine number like OH120 or L90 off of the engine I can find you a manual for the engine also.
This is the list of Manuals available there:
  • 1983 W-W Grinder Inc. Manual and Parts List Super Tomahawk 5-8-2G/C and Tomahawk 5-8-2G/M Chipper/Shredder (40 Pages)
  • 1989 Troy-Bilt Owner/Operator Manual Junior Tomahawk Chipper/Shredder (24 Pages)
  • 1989 Troy-Bilt Technical Manual 4HP, 5HP, & 8HP Models Tomahawk Chipper/Shredder (12 Pages)
  • 1991 Troy-Bilt Owner/Operator Manual Junior Tomahawk Chipper/Shredder (24 Pages)
  • 1991 Troy-Bilt Knife Kit number 1772231 (1 Page)
  • 1992 Troy-Bilt 5HP Model Service Kit (Part Nos. 1901153 and 1901804) For Chipper/Vac (1 Page)
  • 1992 Troy-Bilt Owner/Operator Manual 47260, 47261, 47271, 47272 Chipper/Vac (60 Pages)
  • 1993 Troy-Bilt Sales Brochure Chipper/Vac (4 Pages)
  • 1993 Troy-Bilt Owner/Operator Manual 47265, 47266, 47267, 47276 Tomahawk Chipper/Shredder (44 Pages)
  • 1993 Troy-Bilt Parts Catalog 47265, 47266, 47267, 47276 Tomahawk Chipper/Shredder (16 Pages)
  • 1994 Troy-Bilt PTO Chipper/Shredder Owners Dog Clutch Kit 1902404 (1 Page)
  • Hopefully your model is one of the above.
    Here is link to the Parts manuals:
    http://www.partsandservice.com/html/TroyBilt/cs/
    There are 90 parts manuals there.
    Again with a good model and engine number I can probably come up with your exact manuals.
    Thanks for chosing FixYa,
    Kelly
    1helpful
    Briggs & Stratton Van Guard 16 hp D.C. Chipper with Gravity Flow. With fuel switch on and starting engine four minutes, white smoke apprears and increases gradually, then heavier and chokes itself...
    Sounds like your carb is flooding. Inside the carb, there is a simple valve that shuts off the fuel flow when the fuel bowl is full. If this valve fails, or if the float sinks, then too much fuel is forced into the cylinder and will wash past the rings and into the crankcase. This causes the engine to run very rich. You need to remove, clean and overhaul the carb, and change the oil and sparkplug and probably the air filter too. Find the model, type, and code numbers on the engine and go to www.partstree.com , www.ordertree.com , or your local repair shop to get the needed carb overhaul kit. Some B&S engines have an option of carbs, so look for a name on the carb itself...probably Nikki or Walbro. The carb kit is not very difficult to install, but make sure to get everything very clean before reassembly.
    Good luck.
    Misplaced operation manual for Troy-Bilt Briggs & Stratton Super Tomahawk Chipper/Shredder 8 HP Can it be downloaded? What kind of oil does the chipper use?
    Straight 30w NOT 10w-30
    prefer air-cooled engine oil from mower dealers or some auto supply stores have air cooled engine oil.
    Iā€™m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
    Need to know how to remove collar bearings on tomahawk 8 hp chipper model 15016 thankx
    THAT SHOULD BE A SHIV IF YOU PUT BOLTS IN THE OTHER HOLES AND SCREW THEM IN AND THAT SHOULD POP OFF
    Drive belt and a manual for 8 hp tomahawk chipper shredder
    did you find a manual? mine is 8hp Super Tomahawk, model 47258. I have manual, but not parts diagram. I need parts, flails and tamper. Got any leads? twinblade88 at hotmail dot com
    5 hp briggs & stratton on a chipper/shreader
    if the starter rope fails to retract, then you need to either fix a broken spring, or put a new one in. You'll have to take the engine cover off, and you'll be able to see how to take apart the retractor assembly. Often times, just the end of the spring will break off, and if you have a grinder, you can grind the correct shape in it again, and reinstall it as is.
    Top Briggs & Stratton Heavy Machinery Experts
    ADMIN Andrew
    ADMIN Andrew
    Dmitry Isayev
    Dmitry Isayev
    Are you a Briggs & Stratton Heavy Machinery Expert? Answer questions, earn points and help others
