How do you remove the throat plate?
Not sure what you mean by 'throat plate' - do you mean the stitch plate/needle plate ? If-so, the best way is to drop the feed-dogs by pressing the button in the bottom of the handwheel end panel and you then press firmly on the back right-hand corner of the stitch plate - it should then pop-up on the opposite corner and you can remove it. It's held-in by two spring retainers. When replacing it, position it so that the hole in the front right corner of the plate is over the locating lug first and the right-hand side of the plate is in place, then press the left-hand side down into the grey plastic surround in the free-arm.
Hope that helps.
