Re: Nokia 6300 turning its self off and shutting its self...
The switch off button of your phone has stuck in pressed position try to release it or go to any nokia repair shop they will repair it for free pls rate me thankyou
When the handset fell down, the flex that connect the screen and the panel has shift. Get a screw driver, unscrew the phone and try to adjust the screen.
If after doing his the problem continues you need to change the screen of the phone.
this method will work bt u will loast all ur phone data
switch off ur phone remove sim and memory card now press green key and star key and 3 key continue holding these keys and turn ur phone on while holding these keys.Continue holding the keys if done correctly u can see formatting wait for some time ur phone will start u can release keys when u see formatting on screen.
First, be sure the battery is well inserted and not shaking, if you are sure about the battery, then maybe the software of your phone is corrupt or has virus.
All you need do is to flash the phone with a nokia 6300 software. This can be done by phone experts that deals on softwares.
u use 6300 that was s40 v3 service cell so . 3 calling dont work just go to setting & select option reset my phone to factory setting enter sec. code the phone will reset or try *#7370# .
i already use the "*", "3", "call button" and "on button" but still not working. my
phone is automatically shutting down when i press the switch on button.
It is not starting up. Is there any ways to format my nokia 6300
without turning my phone on? and how can i fixed this problem? please i
need your help.. please...=(
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
this kind of problems occurs when the Phone Software Goes bad try to get that phone to be flashed ista process that repairmans do to give a phone a fresh firmware/Flash File
hi, Please try to hard format your phone..the procedure is Switch off the phone.
Hold down the following three buttons: Green (call answer) button, * button, and ‘3′ button,While holding these buttons, press the power button and switch on the phone.When the message ‘Formatting’ appears on the screen, release all of the buttons..please note that you will lose the datas in your mobile after doing this..hope this solves your problem else please take your mobile to nokia customer care..thank you!!..
