Upon pressing the power button, the power light blinks but does not maintain a constant glow, the monitor itself does not come on.
SOURCE: Dell E172FP 17 monitor keeps blinking
That sounds like the backlight inverter board. Check ebay for the board or a repair kit for it.
SOURCE: Dell E173FP 17" Monitor
I just had the same problem as well - mine happened during a windows update, related? Also, for me the monitor doesn't come one even after disconnecting from computer, nothing, just blinking green light.
SOURCE: Dell monitor shows blank screen, green power light stays on
You have a monitor with a common problem. After a few years some LCD monitorswill
blow a power supply. The problem is caused by parts calledcapacitors
overheating in the confined space of he monitor. If you aregood at electronics repair/soldering you can usually fix he problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htmYou
can take the back cover off your monitor and look for the bad
parts,replace any that look like the pictues and your monitor should
workfine. The capacitors do need to be installed with the correct + and
-connections, note the stripe on the old one and insert the new one
thesame way. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping. I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of computer and printer support/repair
SOURCE: Dell Monitor Problems
It sounds like you have a monitor with a common problem. After a few years some LCD monitors
will blow a power supply. The problem is caused by parts called
capacitors overheating in the confined space of the monitor. If you are
good at electronics repair/soldering you can usually fix the problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts,replace any that look like the pictures and your monitor should work
fine. The capacitors do need to be installed with the correct + and -
connections, note the stripe on the old one and insert the new one the
Buddy
Corporate Computer
www.ccl-la.com
SOURCE: Dell E172FPb monitor black screen green flashing power button
We have a dis-assebly and repair guide posted on our web site at:
www.ccl-la.com/monitor_repair.htm
The problem is usually the driver transistors, our guide shows where they are and what to replace to get your monitor back running again.
I hope this helps, If so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
