Dremel Variable - Speed Multipro Rotary Tool 395 Logo
Posted on Feb 12, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
HOMLITE 33CC CHAIN SAW SPITTING WAY TO MUCH CHAIN LUBE
THE THING IS PUKING LUBE IS THERE AN ADJUSTMENT TO SLOW IT DOWN
Anonymous
Level 3:
  • Master 10,865 Answers
  • Posted on Feb 26, 2009
Anonymous
Master
Level 3:
Answers
10865
Questions
0
Helped
3799719
Points
33142
This homelite saw requires homelite chain oil as there is no adjustment.
How to fix the choke on homlite 38 cc 16 inch gas chain saw
More than likely, your choke became disconnected. I have attached a link from YouTube of a video on this.
There are many useful video's on fixing chainsaws, from simple fixes such as reattaching a choke lever, to complete tear down and rebuilds.
I hope this helps you get back up and running.
Short video on fixing chain saw choke
Nov 10, 2014 • Garden
Yesterday around five i was chopping some logs out of a small tree i felled. i was doing a under cut to the top tru a small bout three inch tree. next thing i know my blade isnt spinning. so i stoped for...
I don't have any poulan saws mine are all stihl and homelite but they all have a chain lock on them .It is located on the front of the motor on top of the saw and if they are hit fairly hard they will lock down on the chain to prevent injury. Try to push the bar forward then pull it back towards the rear of the saw. You should hear it click when it resets.Hope this helps you. Thank you
5helpful
What is the mix for my Homelite 16" 33cc chainsaw?
50:1 is the fuel to oil ratio. Never use petroleum oil (engine or boat motor oil). Always use a synthetic saw oil available from home centers, hardware stores and saw dealers. The bottles are usually graduated to various ratios for a gallon of fresh gas. Always premix in it's own container and shake the container thoroughly each time just before filling the tank to prevent oil starvation. Be sure to use bar/chain oil for the chain as well, and keep the chain sharp and well adjusted. Hope this helps!
2helpful
2answers
I have a poulan 14 inch woodshark chainsaw and it ran fine when i got it but now i have to keep gunning the gas to keep it running and i have cleaned the air filter and cleaned the carb.
Turn up your low speed jet about 1/4 turn. You have 2 holes in the side, one says slow or low and the other says high,, or fast, turn the slow jet in 1/4 or out if that doesn't work, then try it, you will find the right spot. Hope this helps.
3helpful
2answers
Ryobi 540A need manual runs slow/ chain too tight?
Actually, I own one of these battery operated Ryobi chain saws too. It is normal for the saw to run slow. Remember it is battery powered, not gas, so its not going to be a high rpm saw. Be patient whit it, and you'll get about 4-6 cuts per battery. I take mine camping. It sure is nice not having to listen to a two-stroke while relaxing in the woods! Dont plan on cutting lots of stuff, either, or you'll burn up the motor. This thing works great for very mild workloads.
3helpful
Have a 455 rancher saw that is spitting chain oil out, is there a way to regulate how much oil is automatically dispersed to chain?
If it is spitting oil out, then your chainsaw is working properly. When it stops spitting oil out, then you have a problem. However, on the bottom of that particular saw you will find a little hole with a picture of an oil can next to it. You can adjust the lubricant output via the screw located at the bottom of that hole but, keep one thing in mind; the harder the wood or working conditions your saw is being exposed to the more oil will be necesary to keep your saw running smoothly and your chain from prematurely dulling.
1helpful
Need chain saw fix
I would try Poulanpro.com and look at their user manuals for the adjustment. They are different on most saws. Hope this helps
4helpful
3answers
Need to adjust carburetor jets of homelite chain saw
what is the adjustment for high and low settings on a homlite 330 ?
Jan 11, 2009 • Garden
Top Dremel Tools & Hardware - Others Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Dremel Tool and Hardware - Other Expert? Answer questions, earn points and help others
