Fender Frontman 212R 100W 2x12 Guitar Combo Amplifier Logo
juan esteban aviles Posted on Feb 17, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a fender frontman 212r i was playing the guitar with the footswitch on the amp and suddenly it stop sounding i check the voltage but that was not the problem what can i do?'
Mark Meister
Level 1:
  • Contributor 1 Answer
  • Posted on Jul 05, 2022
Mark Meister
Contributor
Level 1:
Answers
Questions
0
Helped
756
Points
I bought one of these used, The seller got rid of it because he had no volume control.
I bought it for $60. I got it home and pulled it apart finding the seller attempted to change out the volume control and broke the foil trace going to center wiper pad to ground....so that was a easy fix. But the real reason for my comment is , I'd be out playing and for no reason I'd have.... NOTHING TO MY SPEAKER...and this happened several times at various events , rather embarrassing and frustrating...
Well I dug back into the amp again.
This time I found ...apparently a child must have stuffed a plastic bead for making necklaces into the Power input Jack J4 and this was intermittently opening my speaker with vibration of the amp. In my case the bead had deformed the contacts and I had no audio to the speaker when i removed the bead. Order a new Power input jack for pennies and changed it out.
If your having a similar problem with your amp, any amp doesn't have to be a FM212R you might want to start here first.
Good Luck
Mark,
Joe Patch
Level 2:
Sergeant:
  • Expert 336 Answers
  • Posted on Feb 21, 2013
Joe Patch
Expert
Level 2:
Sergeant:
Answers
336
Questions
0
Helped
109611
Points
574
Find another speaker to check it with. I've had several fender amps to blow their speakers during loud playing.
5 Related Answers
Anonymous
  • 57 Answers
  • Posted on Apr 24, 2010
SOURCE: i cant get good distortion out of my fender
Start with everything in the 12 o' clock position. Adjust one thing at a time until it sounds good to you.
Fred Yearian
  • 5603 Answers
  • Posted on Jul 27, 2010
SOURCE: Everytime I play on my
You don't say if you are using a footswitch or not... If you are, the switch, cables and connectors are suspect.
If you are NOT using the controller, the switch contacts on the footswitch jack in the 212 are suspect as being intermittent contacts.
If the contact is not making, the OD switch on the unit will NOT work either.
These jacks, and their contacts are JUNK and often cause problems.
Open the unit and increse the tension of the contact springs.
Anonymous
  • Posted on Dec 23, 2010
SOURCE: I have a Fender Frontman 212r amp. The problem
When i turn on my 212R it turns on in drive channel. if footswith is plugged in, then it turns on in the clean channel, but after switching in drive it is impossible to switch it back in clean channel. What could be wrong? Swith position doesnt change anything and it seems like switch is OK.
Azrael SRL
  • 11800 Answers
  • Posted on May 28, 2011
SOURCE: Hi. Fender Frontman amp suddenly
This is a very simple unit: a power source of an linear design, a preamplifier with tone and distort control and an 10 watt integrated amplifier.
If the unit is completely dead then the fault is in the power section: cable, switch or source. To find out which you must check them all with a simple multimeter: cable and switch with an ohmmeter (the resistance should be 0 if good) and the source with a voltmeter - (check the presence of the 2 voltages (25 and 15 volt) at its outputs.
Here you can find the schematic of a very similar one
http://www.schematicx.com/view-schematic/fender-frontman-15g-15r-guitar-amplifier-schematic/
The only difference is the final amplifier chip.
Fred Yearian
  • 5603 Answers
  • Posted on Aug 26, 2011
SOURCE: Hello! I was recently playing
There is something resonating with that note frquency. Often the grille or wiring inside will rattle at certain frequencies. You need a sustained source of these frequencies to find what is causing the noise.
sounds like bad caps and maybe a failing output transistors. Use Deoxit contact cleaner too.
2answers
Fender Frontman 212R crackling noise
After ruling out guitar wiring or bad cables...
Try the 2nd input on the amp
also
Is it on both channels, or just one?
Hello! I was recently playing and found out then whenever I play specific notes on any of my guitars, my Fender Frontman 212R will buzz. The notes that always buzz are drop C, drop C#, any A note, and...
2answers
I have a Fender Frontman 212r amp. The problem seems to be when I put the volume upto past 4/10 [40%] The amp gives out an awful crackling sound and power light etc flickers on and off. I have had the map...
2answers
I get no sound at all when I plug in to the input and its not my lead or guitar, how can I fix the amp?
This is probably not a DIY repair. You best take it to a repair shop. Likely the power amp has failed or other common problems are broken connectors/jacks, broken volume pots, and finally circuit board cracks.
Everytime I play on my Fender Frontman 212R the amp switches betweeen the overdrive and clean channels. I can't even switch between the channels on my own. It does it itself. I need help fixing this...
I cant get good distortion out of my fender frontman 212R can sombody help me with the settings
Top Fender Music Experts
Sean Wright
Sean Wright
Virgil Watts
Are you a Fender Music Expert? Answer questions, earn points and help others
