HP Photosmart C4580 All-in-One InkJet Printer Logo
A
Anonymous Posted on Feb 16, 2013
Ink refill costco hp printer C4780
Rod Eslinger
Level 2:
Legend:
An expert who has written 200 answers of more than 400 characters.
  • HP Expert 307 Answers
  • Posted on Apr 16, 2013
Rod Eslinger
HP Expert
Level 2:
Legend:
Answers
307
Questions
Helped
420006
Points
456
When you get an HP integrated ink cartridge refilled (i.e. HP 60, 61, 74, 75, 901, 92-98....currently offered at Costco today) or if you buy a remanufactured/compatible HP ink cartridge, the ink levels cannot be reset (HP has a smart chip embedded within the nozzle plate at base of ink cartridge which counts the drops and then registers as empty).....so you'll just need to live with it and ignore 'ink low', 'non-genuine', 'counterfeit' messages and similar while you are using these types of aftermarket supplies. The first video below provides an overview of the 'low ink' phenomena, the 2nd video provides suggested cartridge prep/handling instructions when you return the cartridge for refilling:
HP 74, 75, 74XL, 75XL Cartridges - Solving Errors & Warnings:http://www.youtube.com/watch?v=C5ISTGyScWU
Ink Refilling & Cartridge Care Tips - Everything you need to know: http://www.youtube.com/watch?v=FnXoDIblpdU
If the new (or refilled/reman/compatible) HP 74, 75, 74XL, or 75XL ink cartridge refuses to complete the printer alignment following cartridge installation, then the ink cartridge either has a connectivity issue with the flexible printed circuit cable (inside unit where cartridge mates with cable), rear cartridge contacts or cable contacts are dirty with ink residue, or the cartridge is suffering from marginal internal electrical performance. If you run into a problem where the ink cartridge is performing marginally and blocks printing (via the Red X), you can bypass the error message (usually only 1 time per clearing action):
HP Photosmart 4200-4500 5200-5500 Printers -Cartridge Error Bypass (HP 74-75 Cartridges):
http://www.youtube.com/watch?v=UDxRkAGOJaI
HP Officejet J5700/J6400 Printers -Cartridge Error Bypass (HP 74-75 Cartridges):
http://www.youtube.com/watch?v=3X3_D90SSq4
These types of severe cartridge errors (i.e. "refer to documentation" / "incompatible cartridges", "print cartridge(s) problem", etc.) typically indicates the internal micro-electronics of the HP #74/75 cartridge are damaged. The cartridge's electrical wire runs at rear and lower side of the ink cartridge, are very delicate and are somewhat susceptible to ink attack over time, which can lead to premature failures. In addition, the older the cartridge the higher the chance of an internal electrical failure. You can also run a 'Tap 41' diagnostic test to check cartridges electrical health (this is a forced test).....go to www.inkjet411.com for more information on your specific printer model.
5 Related Answers
Anonymous
  • 215 Answers
  • Posted on Oct 02, 2009
SOURCE: How to connect wireless HP Photosmart C4780
here is a general steps to connect a printer to a wireless network
http://www.castleink.com/_a-wireless-printer-setup.html
Hope this helps
Thank you
Testimonial: "Very helpful. Although I haven't yet purchased the HP Photosmart C4780, I wanted to research how it might be connected to my wireless home system."
Anonymous
  • 3600 Answers
  • Posted on Mar 11, 2010
SOURCE: Installed updates now HP printer won't accept refilled ink
HP does not recommend refilling thier tanks, their print heads are built in to the cartridge so if you refilled it before resetting the tanks you will have to go to www.hp.com and run the trouble shooting tool for free to fix your issue. you may have to replace the catridge.
mstanicek
  • 11 Answers
  • Posted on Mar 23, 2010
SOURCE: had ink refilled at costco...now printer wont SPAM ALERT 1-800-532-4187
Go to www.inkjet411.com or www.costcoinkjetrefill.com for tips on how to get around this problem. The printer thinks it is an old cartridge. By resetting the printer it will sometimes fix the problem and let you use the cartridge. Can also use 2-3 cartridges in a rotation to trick the printer
Anonymous
  • 241 Answers
  • Posted on May 28, 2010
SOURCE: Just installed refilled black ink cartridge on hp
By using refilled cartridges you will always have this problem. Each cartridge has a chip that lets the printer know when it is full or empty. By pressing the ok button you may be able to clear this message. However, most of the time you can still be able to print and ignore the message.
Anonymous
  • 1751 Answers
  • Posted on Aug 10, 2010
your cartridge have not been refillied in the right way
you must replace the chips with new ones
How do I clear a carriage jam on my HP D7160 printer?
We suggest you first remove all of the ink cartridges from the HP D7160 printer, then attempt the carriage un-jamming instructions as provided by the others above. If the jam still cannot be cleared then either the flex driver cable has a problem or the service station (below carriage assembly) is blocking carriage travel.
For advanced HP D7160 printer diagnostics specific to your printer model, please refer to 'HP Diagnostics Tests' .pdf file at the following Inkjet411 support site link: http://inkjet411.com/?page_id=1813
Please note that all Costco USA (all stores), Costco Canada/Mexico/UK (most stores), Fry's Electronics USA (all stores), Best Buy Canada (13 stores) support this ink cartridge series. Our network of retailers stand behind the product and performance - guaranteed. For store locations and details on ink refill pricing:
Costco USA Ink Refill Service (465+ stores):http://www.costcoinkjetrefill.com
Costco Canada Ink Refill Service (59 stores):http://www.ca.costcoinkjetrefill.com
Costco Mexico Ink Refill Service (35 stores):http://es.costcoinkjetrefill.com/
Costco United Kingdom (7 stores):http://uk.costcoinkjetrefill.com/
Fry's Electronics Ink Refill Service (34 stores):http://www.frys.com/ads/page51
Best Buy Canada (13 stores):www.geeksquad.ca/inkrefill/
We also have ink refilling centers in many University stores across the USA & Canada, including:
Brigham Young University, Brigham Young University - Idaho, Cornell University, New York University, Queen's University, San Diego State University, University of Calgary, University of San Diego, University of Virginia and University of Wisconsin - Madison
Refill Store Map Locator:http://www.go2ris.com/
Just bring your ink cartridges into any of our authorized refill center locations. The in-store representatives (at either Photo/Electronics support center) are trained to refill over 300 different ink cartridge types from all the major manufacturers (i.e. HP, Epson, Canon, Lexmark and Dell) and can answer any additional questions you may have. It typically takes less than an hour to complete the refill from the time you drop the cartridges off. Our network of retailers stand behind the product and performance - guaranteed. All of our inks are Made in America and closely match original manufacturer's ink quality - we are sure you'll be satisfied with both color 'pop' and image longevity performance.
The RIS InkCenter - the power behind retail Inkjet Cartridge Refill Services: http://www.youtube.com/watch?v=e7tlmEexor8
Save Money. Save The Environment.
Customers who have questions regarding the use of refilled ink cartridges can visit http://www.inkjet411.com or contact us directly at [email protected]
Alternatively, if a refill center is not close to you and you need to purchase a new ink cartridge(s) and are trying to cut costs, we suggest you try a remanufactured ink cartridge from http://www.inkplicity.com/as their ink cartridges typically have the lowest cost in the USA, have a high reliability rating, come with a 1-year warranty and provide free shipping for all orders above $20 (available for US Residents only).
-Thank you
Get the orange plastic top off the black ink cartridge
With respect to your HP OJ J4680 printer, which uses HP 901/901XL ink cartridges, it sounds like this is either a compatible/clone cartridge from overseas in which case you should not remove the orange top as it is molded into the cartridge, or you recently purchased or had the ink cartridge refilled (at Costco, etc.) and the storage clip (which seals the base of the cartridges to prevent the nozzles from drying out) is attached to the ink cartridge. If this is a storage clip, just press hard on the clips top lever at an angle to remove. See our videos on cartridge care tips and how to troubleshoot an ink cartridge error/problem on the HP OJ J4500, J4600 and OJ 4500 series printer models:
HP 901 Ink Refilling & Cartridge Care Tips - Everything you need to know: http://www.youtube.com/watch?v=jTtNj6rN4g4
HP Officejet J4500 J4600 4500 Printers Tap 41 Diagnostics - HP 901 Incompatible Print Cartridges:
http://www.youtube.com/watch?v=S6uATgXxQlE
If you need to purchase new HP 901 ink cartridge(s) and are trying to cut costs, we suggest you try a remanufactured ink cartridge from http://www.inkplicity.com/ as their ink cartridges typically have the lowest cost in the USA, have a high reliability rating, come with a 1-year warranty and provide free shipping for all orders above $20.
NOTE: If you are interested in the top \'refill friendly inkjet printer models\', our suggested list is posted on-line and our internal labs have verified there are no issues (in ink compatibility or color output) with all of these models: http://inkjet411.com/?page_id=3585
INK REFILLING SERVICES (SUPER CHEAP):
Costco USA Ink Refill Service (460+ stores): http://www.costcoinkjetrefill.com
Costco Canada Ink Refill Service (59 stores): http://www.ca.costcoinkjetrefill.com
Costco Mexico Ink Refill Service (35 stores): http://es.costcoinkjetrefill.com/
Costco United Kingdom (select stores): http://uk.costcoinkjetrefill.com/
Fry\'s Electronics Ink Refill Service (34 stores): http://www.frys.com/ads/page51
Best Buy Canada (13 stores): www.geeksquad.ca/inkrefill/
For any additional questions you may contact us directly: [email protected]
-Thank you
2answers
How do I correct my problem with black vertical lines on my officejet 8600 printer?
Try cleaning the print heads using your HP maitenence program of by going into your printers section of the start menu.
How to disassemble
Power on printer and soak up spilled ink with towels. Next we suggest you remove PRINTHEAD from printer and inspect for damage to contact pin(s) on the INSIDE OF THE PRINTHEAD ASSEMBLY. Please refer to printhead removal procedure below for reference (HP Officejet PRO 8600 Printhead Removal & Replacement Procedure):
http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&lc=en&dlc=en&docname=c02871867
NOTE: To gain access to the service menus and advance printer reset procedures (and service tests) for the HP Officejet Pro 8600, 8610, 8620 or 8630 series printers please refer to our HP Diagnostics document at the following link:
Advanced HP Printer Diagnostics (i.e. printer self tests, etc.): http://inkjet411.com/?page_id=1813
Please note that if you choose to refill your ink cartridges with Costco/Frys, etc., the refill comes with a new chip so the ink level monitoring will be reset and function like a brand new HP OEM ink cartridge. We provide professional HP 950/951 ink cartridge refilling services in multiple countries and at multiple retail outlets:
INK REFILL SERVICES:
Costco USA (462 stores): http://www.costcoinkjetrefill.com
Costco Canada (57 stores, more coming soon): http://www.ca.costcoinkjetrefill.com
Costco Mexico (35 stores): http://es.costcoinkjetrefill.com/
Fry's Electronics (34 stores): http://www.frys.com/ads/page51
Micro Center (8 stores): http://www.microcenter.com/site/content/refill-service.aspx
9 Major Universities in USA & Canada
Ink Cartridge Refill Store Map Locator: http://www.go2ris.com/
Our network of retailers stand behind the product and performance - guaranteed. Customers who have questions regarding the use of refilled ink cartridges can visit http://www.inkjet411.com or contact us directly at [email protected]
Alternatively, if you need to purchase a new ink cartridge(s) and are trying to cut costs, we suggest you try a remanufactured ink cartridge from http://www.inkplicity.com/ as their ink cartridges typically have the lowest cost in the USA, have a high reliability rating, come with a 1-year warranty and provide free shipping for all orders above $20.
-Thank you
2answers
I filled my hp 61 cartridges myself.I am having problems getting the ink to flow right,with the black cartridge
When filling cartridges yourself (i.e. DIY kits) you need to ensure that a proper vacuum prime occurs...often this is tricky if the internal foam is not properly 'wetted'. I suggest you take your HP61 ink cartridges to either Costco (most locations) or any Fry's Electronic Stores for ink refilling (typically ~40-70% cost savings vs. new cartridge cost)...the refill operators use a commercial grade ink refilling machine that preps, evacuates, cleans and then fills the cartridge automatically....followed by an electrical nozzle/jetting test. Anything goes wrong (at home) and you'll likely get a refund.
To find the nearest refill Costco store location and/or Costco pricing information, you can find this information at http://www.costcoinkjetrefill.com
For additional ink refill support information or advanced HP printer diagnosis/testing procedures for your printer model, please visit Inkjet411:
My hp officejet 4500 printer won't recognize a costco refill ink
hp notify I am hp tech engineer , you should not use refill ink
2answers
How to reset ink levels on HP Officejet Pro 8600 Premium
shut of both the electrecity and the shut bottom press 10 minutes than replugg and start
Had ink refilled at costco...now printer wont recognize cartridges
2answers
Is it possible to use non HP ink in ths printer? Tried using "remanufactured ink", and concluded that this printer may be programed to block the use of NON HP INK.
It is always recommended to use genuine HP cartridges.
As if we will use the non HP or refilled cartridges, it will reduce the life of the printer.
And we will get an error "cartridge problem".
Plaese use the below cartridges, which are compatible with this printer.
HP 02 Black 660 pages
HP 02 Black Twin Pack 1320 pages
HP 02 Color Combo See single 02 inks
HP 02 Cyan 400 pages
HP 02 Light Cyan 240 photos
HP 02 Light Magenta 240 photos
HP 02 Magenta 370 pages
HP 02 Photo Value Pack 150 photos
HP 02 Yellow 500 pages
HP 02XL Cyan 600 pages
HP 02XL Magenta 555 pages
HP 02XL Yellow 750 pages
3helpful
4answers
My hp printer c4580 won't accept refilled ink cartridges how do i do this rodney
> won't accept
Error-messages? What happens? What does not happen?
Did you refill the ink-cartridges yourself, or did you take it to a company that does the refilling?
k24674
Grand Canyon Tech
Grand Canyon Tech
