Question about OKI B6300 Laser Printer
OKI B6300 Drum problem
Hi all.. i have printer OKI B6300 Four (4) Units, it keep displaying replace toner/drum though i already change new toner, i already check all the posible toner/drum sensor and clean, some boards also is new, the problem is still there..
hope you can help me with this big problem of mine.
thanks! and more power.
  • Sam-Lakeland Mar 24, 2009
    Exactly the same thing.
    Changed toner but syill saying the same. Now Okidata doesnt want to help because we did not buy toner from them. Really bad service.
Hello, com_jedi. I would suggest you contact the OKI Customer Support line in order to address this issue. The phone number is 1-800-654-3282 (800-OKIDATA). For your model unit you would hit options 1 then 4 to get to mono support.
It is possible that you purchased a defective consumable and OKI warranties them for 90 after the date of purchase. If this is a new drum/toner it may need to be replaced to determine if it was a bad chip in the cartridge or if there is some other issue with the unit that is causing the error.
It is also possible there is a misalignment with the sensor that is located under the drum unit. A support tech can walk you through the troublehshooting as it would be a bit difficult to do here.
I hope this helps!
Posted on Feb 12, 2009
SOURCE:
OKI C9800 CYAN TONER SENSOR ERROR
remove drum units and clean optical sensors located at the back end of he drum slots and clean corresponding reflective plates on drum units
Jul 30, 2014 | OKI C Office Equipment & Supplies
Oki b6300 set drum toner cartridge, I replace the toner twice put it still give this message, and the new toner if i put it in anthor printer this message apper eventhough the toner is new and I tried two...
Press the Menu button
GO to "Admin Menu"
Select "System Settings"
Select "Drum/Toner Life"
Choose "Continue Print"
(press Feed/Select - which places a * next to the field)
press the Menu button again to exit
Feb 24, 2014 | Office Equipment & Supplies
Trouble with Oki B6300 drum/toner cartridge replacment. Can't get back into the menu to reset the printer.
Try removing and then reinstalling. If this happens since you changed the drum and toner, then the issue would be with the defective replacement. Way to test is to reinsert the old drum and toner and if this does not happen, then you know the issue is with the new supplies
Jun 12, 2012 | OKI B6300 Laser Printer
My okidata printer won't recognize the toner cartridge.
Did you remove all the packaging material from the cartridge? This can often times be overlooked in some models. Make sure the cartridge is for the same model. Finally you may have a defective cartridge.
Jun 04, 2012 | Office Equipment & Supplies
OKI C6100 has the following error when printer is turned on: Replace Image Drum 562:C Drum Life
Try this:
1.Press Menu = printer displays "Paper Menu"
2.Press Next 4x = printer displays "System Menu"
3.Press Select 1x = printer displays "Factory Defaults"
4.Press Next 7x = printer displays "Reset Toner Life"
5.Press Select 1x = printer displays "Resetting Toner Page Count"
6.Press Ready
Nov 11, 2009 | OKI C6100dtn Led Printer
OKI B6300 DRUM/TONER
try this:
6.Press Ready
Jul 28, 2009 | OKI B6300 Laser Printer
My printer says set drum/toner cartridge. How?
RESET OKIDATA TONER DRUM
1. Turn machine on while pushing and holding the TWO up/down menu buttons at same time.
2. Menu window will show "OKI USER"
3. Scroll to " Engine Dialog Mode" is indicated. Push Enter button.
4. "Diagnostic Mode xx.xx.xx S-Mode is indicated.
5. Scroll to "NV-Ram initial" is indicated. Push ENTER.
6. Window shows "NV-Ram- Initial Table 1".
7. Push ONLINE and ENTER Buttons simultaneously and HOLD for 10 seconds after you see "Executing Reset" appear in menu window.
8. Restart printer.
All toner, drum, fuser and transfer figures return to 100%.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Jul 28, 2009 | OKI B6200 Laser Printer
OKI c5600 drum reset
It usually resets automatically when you replace the drum/toner units. Are you trying to get it to reset before it's supposed to? I don't know of any way you can do that.
Apr 20, 2009 | OKI C5500n Printer
MFC 9700 Drum replacement problem
In the box with new drum is manual how to reset this, however, will not show solution for this particular model. So you ned:
1. Open cover (as to replace drum or toner). On display you will get "Cover Open"
2. Press right arrow under LCD display.
3. Press 1 (digit one) on keypad.
4. Close the cover
Done.
Dec 29, 2008 | Brother MFC 9700 All-In-One Laser Printer
OKI B6300 Laser Printer Logo
1,729 people viewed this question
Top OKI Office Equipment & Supplies Experts
Steve Allison
Steve Allison
WTF Chuck.....
WTF Chuck.....
Clive
Clive
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
