SOURCE: dropped Nikon Coolpix L3
The following blog outlines some repair options for a lens error:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
SOURCE: "Lens not attached" warning when lens is in fact attached.
Hello. Check the area around the lens mount carefully - specifically the contacts. Make sure all are clean and protruding the same. If one is lower than the rest, try 'flicking' it with a fingernail (lightly) to see if it will pop up to the height of the others. It may have dirt or a particle of dust lodged. If this doesn't help, get the lens to Nikon for a check-up.
SOURCE: 'Lens Error'
From the manual: "Turn camera off and then on again. If error persists, contact retailer or Nikon representative."
SOURCE: D3000 Digital Camera with 18-55mm lens: hi,i brought a nikon 3000 , is it compatible with ...
ALL Nikon AFS branded lenses are compatible with the D3000. The AF lenses are usable in manual mode.
Sigma, Tokina and Tamron lenses without the built-in motor are manual mode as well.
To be sure, check the manufacturer;s websites.
Hope this helps,
Andrew
SOURCE: I have the Nikon D3000
Clean the contacts on the camera body and the lens where they meet with a cotton swab lightly dampened with rubbing alcohol.
