I purchased a Terk FM Edge dual-drive FM antenna. Would like to know what kind of wire or cable I should use to between my receiver and antenna. 75 ohm or 300 ohm.
SOURCE: need to connect an indoor FM antenna to the
the indoor antenna you have must have a screw on connector and the receiver has a smooth connector or you would already have it hooked up. Go to Radio Shack and buy a connector that turns the coax into a slip on style.
SOURCE: External FM antenna
The fix for the problem is simply go to Radioshack and purchase their part number 278-267 which is an "F" jack to 1/8" Male Plug. The cost is $6.09. This should solve your problem. The 75-Ohm antenna plug can now be screwed or connected to the "F" connector.
