I heard about the new launch of tissot powermatic, i wanna know what exactly is the meaning of powermatic, is it the same as automatic watch...
Click this link for more help
http://www.wthejournal.com/en/en-direct/article/tissot-powermatic-80-automatic-movement
SOURCE: tissot watch prs 516 automatic
I would recommend going to the following link and follow the instructions for resetting the counters and see if that corrects the issue.
http://www.tissot.ch/data/usersmanual/134-en.pdf
SOURCE: Tissot wrist watch goingin reverse since new battery fitted
It sounds like the battery might be in backwards. They do
have polarity,...it DOES matter how it goes in. Try opening it, and
flip the battery to see if that helps.
Mark
SOURCE: My Tissot Rock Watch is running slow despite new battery
Hi, Try this service center:
Barbara Williams
Old Father Time, LLC
http://www.oldfathertime.com/
(800) 383-4992 within the US
I know for a fact that they repair Rock Watches.
SOURCE: Shortening stainless band for 1st generation Tissot Le Locle
Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and start to unscrew one of the screws.
If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx.
size of pin end diameter using any sharpening stone or sandpaper. Get
an old towel and fold it to make a soft base for work (like small
cusion). As you don't have a special bracelet holder you will need a
pair of helping hands to hold the bracelet steady upright. You will
need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make
sure that the grooved pin ends are facing towel, not the needle and
hammer!!!
Now place the watch on the folded towel, take that needle and smallest
hammer you have and start driving the pin out using light blows. Do Not
hit hard, as you will brake the needle, scratch your watch or even
injure yourself. Watchmakers are using 45 gram hammer, so, calculate
your strength of blows.
After a few blows check if the split end is coming out and when you see
that the end is long enough to grab it with pliers, pull the pin out
with pliers. When pulling, do NOT turn pliers, as pins tend to brake
when twisted. Use firm grip and your strength to pull the pin without
twisting.
After shortening the bracelet,make sure that the pins go back EXACTLY
the same way as they came out- the blunt end first in the hole and the
split (grooved) end last. Before doing that check remaining pins in
bracelet to make sure that you put them back from the right side of
bracelet.
It is recommended to use plastic hammer to drive pins back in or you
will scratch or damage bracelet. If plastic hammer is not available use
an old toothbrush handle (or some plastic item) as an absorber. Simply
put pin into the hole as deep as you can with your fingers, put the
toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
Don't forget to rate, please.
SOURCE: tissot wristwatch model PR 516 GL
I guess you never overhauled your watch.Every mechanism has it's limits - so does the watch movements. Your watch has ETA Swiss made mechanical movement which is very good and reliable, but you have to take care of it from time to time. Mechanical movements are designed to last almost forever if they are looked after and yours isn't an exception. Bring it down to the local watchmaker and ask to overhaul it. It will run as new again and will not let you down. It is recommended to overhaul mechanical watches every 4-6 years. If this will be done, your watch will happily tick-tock on your grand-grand-grand-grand-grand-grand children's wrist and they will remember you with a few good words and respect.
