I need a output plug (male) for a legacy ldsn7 where can i find one or atleast the a wiring diagram.
I have a plug for a different legacy if i only new how to arrange wires in correct order. the diagram on radio is hard to understand where the blk,red,yellow ect... goes. is there a way to find out? pls. help!!
The speakers have a 3.5mm stereo jack, does your tablet have a headphone output? Connnect a Male-Male 3.5mm stereo cable between the two, The Logitech does not have Bluetooth or USB, so if you do not have a headphone output, you can purchase a Bluetooth receiver, plug that into the Logitech with 3.5mm cable, and Bluetooth from the tablet to the receiver
I have a 15000 ultrasource generator the start and stop switch was taken out i need to put it back The problem is i dont know which wire goes where and when i look at the wire diagram the numbers are different the numbers on my unit are 15, 11, 133, 14, 12, The 15 and 11 are the same wires the start and stop switch has 6 males on the back to plug the wires into Does anyone know which wire goes where???
you have the red wire going to the wrong hot lead you need to find a switched fuse that turns on when you turn the car on try the other side of the fuse or a different location
All the wires have colors. Like color wires go together. You can basically rewire a Honda by the color of the wires with out having to use a diagram . The only confusing thing you might run into is , for example, when you have a blue wire with a white stripe that connects to a blue wire with a white band near the connector. If you are trying to connect a part from another year or model , where the harness is different colors, then you may need two different diagrams if you want to attempt to use the part in question. Your best option is to make sure the part you purchase is for the year you have so the plugs and the wire colors match up.
All I wanted was a pinout diagram for the male plug so that I could wire up a new plug. Did not want to have to re-mortgage the house to get that. Thought such info would be free.
Anyway have stripped away all the plastic moulding to reveal the connections so am OK now Thanks
Jim Goldsmith
To solve the problem I tosted the whole mess of wires and equipment and bought new equipment. $8,024 spent and now all the new converters are labeled. The industry needs to mark all equipment with DC-IN 9V or whatever. This is a real problem if you have kids and grandkids and too many different standards.
Your question is not clear, 2002 trailblazer has a towing harness, in order to find each wire, use a ohmmeter and try out each application.
In case of male harness of a camper you can test it with 12 volts in each wire looking which light is on and if it is different position cut wires and make similar wiring
