Can I use my hisense controller to control my cable box
I have a simple direct tv cable box is my daughter s room. We got her a 32in lcd flat screen hisense for xmas. I have tried ever code any one could come up with to program direct tvs remote to control thw tv and nothing works. So can I use the hisense controller to control the cable box. All I need it to do is turn on and off the box and change the channel
It could be caused by problems with the TV's cable connections.Or problems with the input devices.Or the firmware is outdated.The power supply board could be bad.
The Hisense HX32N2176H will display an HD signal of 1366x720 with the HDMI input. (Any resolution above 480 (lines of pixels) is considered HD.) However, this isn't a full-HD (1080) capable TV. See https://www.hificorp.co.za/hisense-32in-81cm-hdr-led-tv-hx32n2176 for the specifications. Click on the Technical Details tab.
If your LCD TV or monitor has stopped working, or is displaying one of the following
symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can
examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life
of your monitor or TV by several years.
Hello Four digit universal remote codes for Hisense TV are: 0073 0182 0216 Five digit universal remote code for Hisense tV with RCA RCR312W remote control is: 10748
Make sure closed captioning is turned off on the TV as well as your cable box or satellite receiver (if you are using them and they have that feature). Captioning is probably on and set for text mode.
I, also, have the Hisense LCD 1504 and cannot turn it on with the original remote. I have to use the ON button on the side every morning. You have to hold this button in for a while then wait a while and presto, the blue button shows on the front and the picture comes on. If it fails to work the first try, just try try again. It does work for me this way. We had this same experience with the TV in our room at a Hotel where we were on vacation and the TV worked fine when we turned it on using the side ON button. It just takes a while for the picture to appear. Hope this clue will help someone.
My daughter's LCD which is barely used started showing horizontal coloured lines.I read that the LCD's are vunerable to static/charge build up and also power surges.
I unplugged my daughter's TV and it is now working properly however we now unplug the TV when it's not in use.
I was considering purchasing a larger model for the faily room but Not going to waste my money until they improve this rechnology.
