Onkyo TX-SR605 Receiver Logo
Jay Viveiros Posted on Feb 11, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Tx sr605 shuts off after being turned on for 5-10 seconds
Im just wondering if anyone knows the most common reasons why this might happen and what i can do to fix it. a relative gave it to me cause its not under warranty and im not entirely sure i want to take it into a shop and pay who knows what. if its even remotely possible that its something i can do, or replace id rather give it a go
  • 1 more comment
  • rally_MFF Mar 07, 2009
    Bought a Tx-Sr605 from FRYS as a return item. Sales rep said it had been fixed. The job order stated the unit would shut off after running for a bit. I took it home and at first it ran fine and stayed on for a couple of hours. Then just the other day in the middle of watching "Heroes" on our DVR, it decides to start shutting off every 20 minutes. I checked all the speaker leads to make sure nothing was crossed, plus it ran days prior with no issues. I am going to send it back again for repair, with any luck they can fix it for good. :)
  • epbiggs Mar 11, 2009
    I've had the same problem for a while now. Occasionally it just decides to turn off. When I try to turn it back on, it will just shut off again. Eventually, it will work, sometimes for days or weeks before it happens again. I replaced all of my speaker wire... didn't fix the problem. I took it into an authorized Onkyo repair shop and he couldn't find the problem. Oddly enough, after I hooked it back up, it worked for a couple of months before the problem started again. It's not a heat issue as it's winter and my house is very cool right now, and it's not enclosed in a cabinet and has plenty of air flow.
    I think it has something to do with a prevention circuit but have not been able to find any solutions either on the internet or through Onkyo support.
  • 240sx1990 Apr 21, 2009
    I have the same problem. My wife noticed when dusting if we just tap the receiver it shuts off. some times it shuts off it self some times ok for a month. HELP!!!
Anonymous
Level 2:
  • Expert 86 Answers
  • Posted on Feb 13, 2009
Anonymous
Expert
Level 2:
Answers
86
Questions
0
Helped
25400
Points
160
Try checking the fuses, it shouldnt shut off after 5 to 15 seconds this is the 1st time ever hearing about that try that an let me kno wut happens
hopfully that can give it a go
tip
Onkyo TX-SR605 Manual Download
Download Onkyo TX-SR605 Manual
Models: RC-682M / TX-SR605 / TX-SA605 / TX-SA8560
Have you misplaced your Onkyo TX-SR605 Owners Manual?
Would you like a digital, searchable, pdf version of the Onkyo TX-SR605 Users Guide?
Follow this link to download a pdf version of the operations manual.
I hope that helps.
________________________________________________
RC-682M Remote Code List & Programming Guide Here.
tip
I hope that helps.
2answers
Won't turn on.standby light on,fuse under cover is good.what next? onkyo tx-sr605
The only thing to test would be to disconnect all speaker wires at the receiver then turn it back on. If it still won't turn on, it's an internal power supply issue and will need service. If it turns on, post a comment and I can walk you thru further troubleshooting. Hope this helps
Onkyo TX-SR605. Low or no sound output
Does any good sound come through headphones, if you plug any in?
tip
Onkyo TX-SR605 Remote Codes
Download Onkyo TX-SR605 Remote Codes
4 Digit Onkyo Remote Codes
Have you misplaced your Onkyo TX-SR605 Remote code list / Owners Manual?
Would you like a digital, searchable, pdf version of the Onkyo TX-SR605 Universal Remote Code List Users Guide?
I hope that helps.
Download Onkyo TX-SR605 Users Manual Here.
tip
I hope that helps.
2helpful
3answers
Onkyo tx-sr605 remote codes
Just go to Onkyo.com support.. all the manuals are online in pdf form
2helpful
I purchased and returned to tx-sr605 receivers. The problem with both, after setup, is they both shut down. The second one laster the longest about 5 minutes, before shutting down. I really want this...
Does the receiver location have adequite ventilation? They have a built in internal temperature sensor that will shut the receiver down if the internal temperature rises past a certain point.
Make sure that the ventilation holes have adequite air spece around them, and do not install the receiver in an enclosed space.
Onkyo TX-SR605 video problems
Bypass most reviews say video area is still alittle shaky
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
John
John
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
