Watches Logo
A
Anonymous Posted on Feb 15, 2013
Canada esq watch repair
Need new bracelet links
5 Related Answers
A
Anonymous
  • Posted on Jul 28, 2007
SOURCE: My watch dosen't fit
Have a look at bracelet clasp exetnder from RTL Watches
Anonymous
  • Posted on Dec 30, 2007
SOURCE: Changing links for a Casio watch bracelet
solutions already mentioned(casio wristband) worked for me. However the first link took me forever to remove as I found it hard to envisage what I what attempting. Attached is a pic of a disassembled link which hopefully might help someone....BPB547b9a0.jpg
escapement
Arturs Kalnins
  • 2338 Answers
  • Posted on Dec 21, 2008
SOURCE: ESQ watch parts
Type in your browser: 1) ESQ watch bands
2) EQS watches
3) ESQ watch bracelets
4) ESQ watch parts
Try all of these and you will find numerous sites (too many to list here).
escapement
Arturs Kalnins
  • 2338 Answers
SOURCE: I have a bracelet link
If you are ready to take that risk, here is how you can do that.
First- get watch on your wrist and by squeezing the bracelet count how many links you have to take out to make it tight enough (say 4 for example).
Check the sides of a bracelet. You will notice that the upper bands metal is flipped over the bracelets side. Take tweezers or small pliers and unbend one of these. Try to do as little damage as possible.
When it's done, you will see two metal staples inserted into the bracelet. You have to pull them out. While pulling out, remember how they where positioned, as you will need to drive them back in the same manner.
So, when the staples are out, do the same on the other side of bracelet. Now you have bracelet in two halves.
Count off 4 links and undo the staples in joint of 4th and 5th link in the same manner as previously.
When links are out, take the staples and drive them back into the bracelet koining two ends together. You have to do that exactly the same way and position as you took them out.
When all staples are in place, bend the metal back over to the bracelet sides.
BE WARNED: as you gonna do it first time, be ready that you can damage the bracelet or can not put it back together.
Good luck
escapement
Arturs Kalnins
  • 2338 Answers
  • Posted on Jan 21, 2009
SOURCE: How do I shorten watch bracelet?
You may have arrows inside bracelet.Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and start to unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
Don't forget to rate, please.
I need to get a spare bracelet link for a Seiko SMA075. Where is it available? Thank you.
You can get bracelet links for Seiko watches at Coserv, Seiko's main repair center located in New Jersey. The phone number to Coserv is 1-800-722-4452. If for some reason your links are discontinued occasionally a local watch repairman will have spare links! I hope this helps!
3helpful
Esq bracelet watch stainless sku 905-00001 -smashed steel-crystal estimate
Any watch repair shop will fit new crystal and give real time estimate.
May 18, 2011 • ESQ Watches
How do you remove the end link?
take it to a repairer is my advice. but if you want to try you need a very lite hammer a very fine nail and a block to place the bracelet on its side. see what i mean..you do need the correct tools for this job as you may scratch the watch or damage the pins and barrels in the bracelet..place the watch on the side place and you should see the pin thats holding the bracelet section hit the pin on top with the very fine nail and it should push the pin through the bracelet you have to do this twice also there will be either 1 or 2 barrels inside the bracelet when you knock through dont loose these ..but you will be in tears by now as you have prob damaged your bracelet repair could be 200.oo .....instead of 20.oo to remove links....
9helpful
New battery install in my esq e-5290 watch
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all ESQ watch manuals. Rate me, please.
Mar 05, 2010 • Watches
I need to repair a couple ESQ watches, I am kiving in Europe but I can't see to find an official dealer
Esq currently only has authorized retailers in Central America, North America, and the Caribbean. You might have to send it to an authorized retailer outside of Europe as I don't believe they have any there. For more info go to their website where you can email then and ask them what they suggest you do as far as getting the watch to them to be fixed.
http://www.esq-watch.com
2answers
New band
You can either contact Movado directly (they make the esq watches) or you can ask any REAL jewelry store to contact the company for you and ask about this as long as they carry either Movado or Esq in their store (don't ask the jewelry counter at your local department store).
2helpful
ESQ watch parts
2) EQS watches
4) ESQ watch parts
Dec 21, 2008 • Watches
Top ESQ Watches Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you an ESQ Watch Expert? Answer questions, earn points and help others
