When only the Bottom oven is on, the inside bottom of the Top oven is over 50degrees C. This can be a hazard if someone opens the top oven and does not realize even thought the top oven is not on, it is very hot to touch inside. This is a new oven installed about a month ago. It has been like this from new. It also has a very strong when it is on. The service engineer said the smell would disappear after a couple of days and the high temperature inside the Top Oven when not on is normal. Can you help ?
SOURCE: GLEB27T8ABA Frigedare Double wall oven electric
check the fuse/breaker for the bottom element
SOURCE: bottom oven of dacor double oven
I found the lower circuit breaker had been tripped. That didn't fix the problem but upon further inspection whoever had worked on the unit years ago had dropped a screwdriver that had lodged between the oven wall and the rear casing and shorted out the lower heating element. I removed the screwdriver and oven works fine now. I don't think that will solve the cmmclow problem but maybee the curcuit breaker is tripped.
SOURCE: GE monogram double oven display getting extremely hot
Usually the knob type controls uses the bulb for temperature regulation. There is usually only one adjustment available - otherwise the thermostat has to be replaced. - that dial with the temperature graduations on it. the whole unit - the bulb in the oven is connected to it.
SOURCE: thermador SC302 double oven the top oven is not getting hot
Thermador double oven, in Montreal Quebec. Similar problem with the display fading out. Thermador should step up to the plate or be obliged to through legal action.
SOURCE: Zanussi ZDQ 595 fan oven not heating
Here is a free video to help you with your cooker fan motor problems
and how to fix them
For all your free videos on appliance repairs remember to
mark us down and leave feedback please
For all your parts visit our site http://www.apart4u.co.uk
