The transducer cable on my hummingbird depth finders cut in half. Can it be repaired.
SOURCE: Replacement of an old Impulse QT206
I believe it is the same model. Even if it is different, it will probably work if it has the same type of plug.
SOURCE: Marine Faria depth finder, with thru the hull transducer.
I'm having the exact same problem. I spoke with the service manager at Faria (Ted) and he was thinking that as long as the gauge is showing a reading, it should default to reading the depth. I'll probably send the guage in to FARIA - they'll repair it for $55. You bring up a good point - maybe the transducer is bad? I put a call in to the Tedmeister to see what he thinks. I'll post if he sheds any light.
SOURCE: lowrance depth finder missing adapter cable
I own a 1995 Four Winns and what you need is a Lowrance LSM-1 depth
finder unit. It accepts the two pin lead from the transducer and send
the depth reading to the dashboard display via the 6-pin connector.
There is also a three wire harness (red/blk/wht) that connects to a
power supply.
The reason I know all this is my depth finder
fried a couple years ago so I removed the Lowrance LSM-1 from the boat
in order to find a replacement. Unfortunately, this was an OEM part
that is not available from Four Winns or any aftermarket source.
Probably your best bet is to look in a boat salvage yard or purchase an
aftermarket depth finder.
SOURCE: My depth finder loses its depth reading at about
You need to set the transducer lower. When at speed, the hull of the ship raises up out of the water and hence your transducer is probably not deep enough at these times to give a proper reading.
SOURCE: Bottom Line Fishin'Buddy II Fish/Depth Finder user guide/manual?
i have an older fishin buddy 2 bottom line sidefinder i need a manual, a bracket that holds it to the boat and the battery holder / handle i hope you can help me with this my email [email protected]
