Watches Logo
Posted on Feb 15, 2013
Michele deco diamond watch
Will not keep time. Te second hand moves but the hour and minute hand will not on their own.
5 Related Answers
A
Anonymous
  • Posted on Oct 20, 2007
SOURCE: My Aquaracer second hand problem
This is most likely the "battery change indicated" feature of your watch.  Change the battery, and see if the problem goes away.  If it does not, then it could be a problem with the stepper motor, which will require a watchmaker.  Of course all of this is dependent on the assumption that your watch has a quartz movement.  If it is an automatic, or mechanical you have bigger problems.
Anonymous
  • Posted on Dec 11, 2009
SOURCE: The second hand of my Tissot watch T870/970 starts and stops.
Hello!
Absolutely astonished by this "solution" from escapement.
This watch is working perfectly - it is simply giving its "end of battery life warning".
escapement
Arturs Kalnins
  • 2338 Answers
  • Posted on Feb 25, 2010
SOURCE: Bulova 96R31 keeps time + date, but the chronograph does not work
The problem is in chronograph module or related gear train. To find what exactly the problem is, special tools and equipment is needed as well as watchmakers knowledge and skill. There may be just an underpowered battery, but according to your explanation, I tend to think that the first causes mentioned by me are the right ones. Visit your nearest watch repair shop and ask to check your watch for any faults. Rate me, please.
Testimonial: "I'm the one who submitted the question. Thank you, I will visit a watch repair shop. It's a shame the watch is only 2-3 months old! Thanks again "
Anonymous
  • Posted on Mar 25, 2010
SOURCE: Sweep 2nd hand operation & watch time setting on my Pulsar watch.
The larger second hand on the Pulsar PF8036 is part of the stopwatch feature. The upper button starts/stops the stopwatch feature, and the lower button operates the lap/reset function. Why they made the larger hand work only with the stopwatch instead of the smaller hand to the left is beyond me, but that's how it is designed.
Jimmy Accardi
  • 102 Answers
  • Posted on Aug 19, 2010
SOURCE: Citizen watch secondhand not moving
its a solar watch meaning you have to completely charge the watch under artificial light for 24 hours or full sun for 6 hours
My michele watch keeps time for a few hours then stops. I have a brand new battery in it.
Hey, I am having the same issue. After a few hours, time stops but if i pull out the crown and push back in, I'm back in business, but after a few hours same thing. Make since the stop watch is on and i am having the worst time figuring out how to turn it off. The chronograph instructions for the Deco are not easy to understand.
Type of battery in Michele deco diamond watch?
395/399 Duracell on Ebay.
I gave up trying to change the battery last time and had a store do it. This time I was determined to do it myself like I do for the dozen or so watches that we have. The Michelle Deco is a bear, as once you take the back off it has a battery restraining bracket that requires a VERY SMALL screw driver and a lot of patience when it is time to re-assemble it. If you are up to trying it yourself you better have great eyesight, steady hands and the right screw drivers (a magnetic one helps get that tiny battery retaining screw back in). It took me almost an hour but I did it. Good luck to you.
1helpful
I didn't wear my Michele CSX 36 w/ diamond watch for a few days..When I went to put it on the time was wrong. So I tried to correct it and now it has not kept accurate time w/in a 24 hr period. Fo
I am pretty 100 percent sure that Michele CSX 36 diamonds only comes with a swiss quartz movement not an automatic movement.
So the problem seems to be that the battery is dying and need to be replaced. Stopping and going is usually a sign of a battery dying in a swiss quartz movement.
So it should be nothing major and just a battery.
1helpful
I just recieved a tissot pcr 200 as a gift and the large second hand is pointed to 12 doesnot move the small second dial is working as are the hour and minute hand
your watch is a chronograph or stop watch. the large second hand that is pointed at 12, it is the second hand of the stop watch, it moves when you press te upper right button and it stop on that button too. when it stops the lower button is the reset. i hope i had been helped you.
Can i remove links from a michele deco mini watch
Any watch repair shop will usually do it for free or under 5 dollars. You can do it yourself with care and very small set of screwdrivers which are probably about 10 to 20 dollars at any department store. I recommend a shop, and they can usually do that for you in less than 10 minutes
4helpful
HOW DO I CHANGE THE DATE ON MY MICHELLE DECO WATCH
Turn the dial toward you and pull out. Then turn the dial away from you to change the date (you can only go upward in date).
1helpful
2answers
How do i get the day to match the date
Here is step by step instruction as well as the picture.
Please click on the link
http://www.michele.com/wcsstore/Michele/images/instructions/michele_instructions.pdf
I hope this will help you resolve the issue.
Thank you for choosing fixya.
2answers
Brand New Watch second hand won't move. won't keep time.
The watch has a problem in the timing module and the second hand won't move (a cog wheel issue) this is clearly a manufacture defect that can not be remedied and should be returned since it is under warranty.
4helpful
I just bought my wife a michele csx-36 watch. Its brand new. The watch runs for about one day then stops . What do you think it is. We did replace the battery already. Thanks
that happened to me too...the watch repair man told me that I had the stop watch on. The stop watch should serve as a stop watch, not the second hand. The second time on your watch is the small dial at the bottom middle of the face. Once I turned off the stop watch feature, my battery life is fine...I have not had to change my battery in over 2 years now. HOpe this helps.
2helpful
2answers
My michele watch chronograph is stuck
Have a watchmaker fix it...there isn't anything you can do.
Top Michele Watches Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
NOEL
NOEL
Are you a Michele Watch Expert? Answer questions, earn points and help others
