Have switched off cleaned out restarted no difference
SOURCE: Our fridge / freezer is freezing everything,
our fridge is old but is freessing every thingit is on the lowest tempture
SOURCE: RLA30 Fridge freezing food on lowest setting
From the symptoms ,I would recommend that you have a new thermostat fitted.
This is the cheapest option., fig's do not go wrong that often
Any comment welcome.
Thanks and a merry xmas.
SOURCE: How to change the thermostat on a Hotpoint RLA30 fridge
It is behind the knob your are adjusting to change the temperature.
It is very easy for me. Don't know how easy for you and your electrician friend.
SOURCE: my fridge is frozen at the back but seems too warm
Let this unit completely defrost and thaw(sevral hours) which might bring it back with little or no additional repairs.These units will lock up on excessive ice and will not circulate...good luck
SOURCE: Swap door sides on hotpoint future RLA30 fridge?
tip unit over on side,placing an old blanket or similar on floor under unit.there are 3 little bolt/screws holding each bracket to the underside of unit,unscrew these/lay brackets on floor, slide door down off pin on underside of top.and unscrew this pin.change over from right to left replace door onto pin replace bottom hingepin,adjust door for" squareness " and tighten all screws lift back upright and switch on...will take a little time to settle down temp wise.... make sure seal sits tight all round good luck ..geoff
