My tv has hdmi ports available
SOURCE: laptop to tv
If your tv don't have s video input,you can get an Svideo to RCA cord.
If the tv does have s video input,just get an s video cable and plug it into the tv and computer s video ports and follow the steps below for setup.
Before you start, change the display settings to 800 x 600; you need to do this since most TVs will not support higher resolution settings - this is ok, however, since you do not need higher resolution to enjoy your DVDs or to view your monitor's display on your TV. Read below about TV/VGA resolution comparisons. Also, make sure all of the hardware is connected before turning on the computer; you may have trouble getting the video card to recognize the TV as the second monitor - the option on some Dells is to change to "Clone" in Nview. But "Clone" is grayed out unless you have the RCA connector on the far end of the "S to RCA" cable, terminated in a VCR or TV.
1. Connect the "S-Video to RCA" cable or the "Pro S-Video to 3 RCA" cable to the "S-video out" of the computer and to the "video in" (yellow RCA jack) on the TV. NOTE: This step must be performed before you start up the computer. Make sure that your TV is set to "recognize" the RCA/yellow video-in jack; you may have to play with the "aux 1", "aux 2", or "line-in" selections on the TV or the TV's remote control. The S-Video jack on your computer may be a 4-pin or 7-pin jack that is usually on the back of the computer.
Windows XP:
- Click on Start, Control Panel.
- Click on Display
- Click on Settings
- Slide the "Screen resolution" area slider bar toward Less until the setting reads 800 x 600. OK, you may not like how your screen looks at this setting after usig high-res settings, but you'll certainly enjoy your DVD on your TV!!! You can always change the res back when not playing DVDs.
- Click Apply
- Press the FN key and your computer's corresponding "F-number" key. For instance, on some Toshiba laptops you press the FN+F5 or FN+F7 simultaneously four times to get the TV-Out setting. The "FN" key is a short-cut key on most laptop keyboards. Note, the combination keys that you may have to press depend on your laptop.
- Start playing your movie or presentation.
- There may be additional adjustments that may be required. If the TV display is shifted to the right with a black vertical bar on the left side you will have to perform additional settings. "The computer runs Windows XP Pro and has a "Radeon IGP 345M", Under 'Display Properties', 'Settings', 'Advanced', 'Displays', click the "TV" button, then 'Adjustments' tab. There you will find options to change the vertical/horizontal size and position. Once you have switched over to use the tv you can simply adjust these settings while you watch the display on the television to get it looking the way you like."
Microsoft Windows 98, Microsoft Windows Me, or Microsoft Windows 2000:
NOTE: To use the TV as the primary display with the dual display function, you need to enable the TV setting every time you start your computer.
2. Click Start, point to Settings, select Control Panel, and choose Display.
2.1 Under the Display Properties window, ensure that the color depth is set to High Color (16bit)
2.2 Click Advanced Properties under the Settings tab; this brings up the ATI or SAVAGE video card features.
2.3 Click on the Display tab; this gives you the output options.
2.4. If you have an ATI video card the "Displays" tab gives you the output options. If the TV is detected, it shows the power button on. The button next to that gives you adjustments for the picture, kind of like those to center the view on your monitor. On the bottom are some blue buttons.
2.5 Make the TV the primary display and the monitor secondary. The default settings on the rest of the adjustments may not need to be changed.
To make the TV the primary display you have to select "monitor 2" (you do that by selecting monitor 2 with the mouse" and then "moving it" to the left of "monitor 1". By switching the position of the monitors in your display settings you effectively make the monitor on the left the primary monitor.
Videos and mpegs play on an "overlay" method and can only play on one monitor at the same time, thus, you have to decide which monitor you want the video overlay to play in...and since the idea is to watch the video on your TV, you thus have to make the TV the primary monitor.
2.6 If you have the SAVAGE graphics card you need to do the following on the display tab - go to the settings tab. There's a drop down menu with 2 monitors, select the first one. Click on the advanced button. There's a tab titled "s3 duo vue". Choose that tab, and click on the tv option. If you do not follow these steps you'll get a message from the savage image card control stating "You must activate the tv first." NOTE: To use the TV as the primary display with the dual display function, you need to enable the settings every time you start your computer.
3. Click OK to close window.
3.1 Click OK to apply the changes
NOTE: The S-Video to RCA Adapter must be attached to the unit or the TV option will be grayed out.
4. When the DVD player was showing the movie, the TV will display it, but the monitor window will be black unless you have dual display capability on your computer.
5. Your TV may just happen to be able to support the 1024 x 768 pixel resolution that the computer may be set to, however, if you lower the resolution to 800 x 600 the movie will probably play much smoother without any noticeable drop in picture quality.
6. Video Formats. You need to make sure that the video format selected on your computer is the same as the video format required for your television. There are some computers that are sold in the USA with PAL-B as the default video format; you need to change it to NTSC-M for TVs in North and South America. There are basically three television video formats, NTSC, PAL and SECAM. NTSC is used in Canada, Japan (NTSC-J), USA, Mexico, Central and South America. PAL is used in most European Countries, Australia and New Zealand. SECAM is primarily used in France and the old soviet republics.
Remember that your monitor's VGA resolution and TV resolution is measured differently since they are different standards and were meant to be seen at different distances. If "pixel resolution" was used to measure TV (NTSC) video then the approximate resolution of a regular TV would be 448x480. Your TV does not need to have higher resolution since it was not meant to be seen as close as your monitor. Regular TV was meant to be seen from a viewing ratio (viewing distance to picture height) of 4-to-1. An HDTV usually has a larger screen size and thus requires higher resolution, since the viewing ratio is about 3:1. You may have to re-arrange your TV viewing distance if you get an HDTV - since it's not going to look good if you just plop it in the same spot as your analog TV; you have to adjust the viewing distance.
Please Rate this a fixya
SOURCE: Connect Laptop to TV via USB
I want to connect my Toshiba Laptop to my Philips LCD TV, any ideas what cable I need to purchase?
Thanks
SOURCE: I have an Acer Aspire 8930G trying to connect to my TV with HDMI
After you connected the HDMI Cable to the TV...Did you press the FN + F4 Key on the keyboard... The first screen you will see is the notebook screen is blank and the TV has got the desktop on top of it...The second time you press the FN + F4 then you will see thedesktop on the notebook and as well as the TV...The third time you press the FN+F4 you will see the desktop on the Notebook...
SOURCE: How can i connect my hp dv5t laptop to tv.My
Check it this link out
http://www.geekwithlaptop.com/how-to-connect-laptop-to-tv
http://www.online-tech-tips.com/computer-tips/how-to-connect-your-laptoppccomputer-to-your-tv/
You will be abo knwo What connector is required.
Hope this will solve your Problem.
SOURCE: i try to connect my
Once you made all the proper connection, meaning the hdmi cable from your laptop to your tv, and tunning your laptop to the right hdmi port (like hdmi side, rear1 or 2 however many hdmi input your tv has). Then I believe on acer model, you need to press the FN button and the F5 button at the same time that switches your external video source, Leave the Fn button press and then slowly press the f5 button key until your screen is display on the monitor HDMI. Like said earlier, you need to make sure the tv is tuned to the correct HDMI port.
