Question about Garden
Blockage in pump of huskey 2600psi
The engine runs like it is trying to pump, no water is discharging from where the pressure hose attaches. When the hose is attached, you can hear the pressure build up, and when the handel is engaged, it squirts for a second then nothing.
    Filmmaker:
    Uploaded 5 video answers.
    New Friend:
  • 55 Answers
You may need to have the pump replaced. Most Husky pumps under 3000 psi don't have parts available. If you bought it within two years, the pump should still be under warranty. Check with Home Depot for service centers near you. They should be able to verify if it qualifies for a free replacement based on the serial number.
Posted on Feb 15, 2013
SOURCE:
  • 101 Answers
SOURCE: pressure washer won't build pressure
The problem sounds like its in the handle.. trigger mechinism
Posted on Dec 15, 2008
SOURCE: Ex-Cell VR2500 Builds Pressure but Won't Spray
I have a similar problem and diagnosed it to be a problem with the gun. I spoke to a technician that services this pressure washer and he walked me through all the diagnostic steps. The pump is working because there is pressure being built up and the gun sort of works because you can get water out before the washer is started. The technician said that the mechanism inside the gun is either clogged or broken. I am going to Home Depot or Lowes to purchase a new gun and will try it tonight. Guns are only about $30-40. He said generic is fine as long as the thread matches and PSI is in range. Good luck!
Posted on Aug 14, 2009
  • 109 Answers
SOURCE: I have a Husky pressure washer with a Honda
check the quick disconnect to the wand these are spring operated and can get stuck
Posted on Aug 23, 2009
  • 174 Answers
SOURCE: Troy Bilt pressure washer model 020209 will not
A leaking gun will kill all the pressure. You may need to repair or replace the gun
Posted on Sep 17, 2009
brado83
  • 106 Answers
SOURCE: Pressure washer starts then shuts down in 2 seconds
hey mate,
It sounds like your bypass valve/unloader valve is sticking when pressure builds up in the lance,hose and head the pressure cleaner changes to a recirculate mode so it does not blow out hoses or seals or causes any damage to the unit, the bypass valve is the component that activates this sequence if that valve is stuck it will just try to continue to create pressure which in turn puts load on the engine and stalls it...
That is why it starts up straight away and only when it builds up pressure is when the engine stalls.
You would be best taking this to a qualified pressure cleaner technician as there are alot of little parts and orings plus the the head will need cleaning up and the bypass valve lubed, they may not of seen this at the service as it is hard to test a unit without the suited hose and lance... Often use will help this problem when a unit sits for a period of time that will cause issues such as this!!!
Regards
Brad:)
Posted on Sep 22, 2009
Why doesn't it work when the water hose is attached?
Pressure washers can only be started/run with water attached. No water burned out pump in 5 seconds! If pump puts out high pressure water without wand/hose attached, bad wand or hose, if not bad pump. Replace pump.
Apr 05, 2016 | Garden
My chevy Venture van still overheating after radiator replaced, temp gauge replaced and fans fixed. WHY?
You may have air trapped in the cooling system. This will cause overheating. When you fill the system, there is a small brass air purge valve above the coolant pump and another on the thermostat housing. These need to be loosened and trapped air released when filling the cooling system.
Mar 19, 2015 | Chevrolet Venture Cars & Trucks
Water pump runs constantly but no water pressure or water comes out of hose.
Lots of possibilities. Inlet filter might be clogged. I once had a lizard crawl into a water feed line, totally blocked the feed. Check valves might be stuck closed. Discharge hose might be plugged. Pump might be trashed ( if it is a vertical engine it is probably a throw away pump) Nozzle might be plugged.
Disconnect the hose at the discharge and turn on the water supply. It should have a stream of water even without the motor running. That will check the inlet filter, feed pipe and check valves.
Oct 07, 2014 | Garden
Won't pump water
UNPLUG PUMP AND SEE IF THE IMPELLER IS JAMED, IF IT SPINS FREE TRY IT WITH A SHORT DISCHARGE HOSE. POSSIBLE BLOCKAGE IN DISCHARGE HOSE WILL TRAP AIR AND WONT LET PUMP PRIME.
Apr 19, 2014 | Cal Pump 5500 GPH Waterfall Pump
The machine is washing but the water will not drain after the wash cycle
if the washer spin's than you have a blockage,most likly it is in your water pump.take the discharge hose and lower it in a bucket,if no water come's out than most likly it is in the water pump.you will nead to remove as much water as you can by hand.also you will nead a pot or bowl to catch the water when you remove the water pump from the discharge hose and the large hose that go's from the outer tub and the water pump.with the pump off you should be able to look inside the pump and see the blockage and remove it.
Dec 26, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
I HAVE A BRAND NEW TROY-BUILT 2600PSI pressure washer. I have used it twice for about 1/2 hour each time. It worked perfectly. I tried to use it today with everything hooked up perfectly. The Honda engine...
Sounds like the governor is stuck. My pressure washer speeds up when it has to pump. Don't know if yours uses vacuum to trigger governor or direct linkage. Good Luck.
Jul 04, 2009 | Psi Blue Max 2200 High Pressure Gas Power...
I hAVE A 2600 PSI HUSKY PRESSURE WASHER, AND I HAVE NO PRESSURE GOING TO THE NOZZEL. i HAVE CHECKED EVERYTHING AND EVERYTHING IS ATTACHED.
remove the pressure hose and turn your water supply on and water should flow thru the pump on out where the pressure hose is. If not you have a blockage in the pump.
Jun 07, 2009 | Garden
Karcher 2500 no pressure problem
sounds like you have an inlet blockage to the pump or not enough volume to feed the pump. make sure hose is turned full on when washing and see what happens. if not you may have to remove adapter wher hose screws in and check for a blockage.
Jul 13, 2008 | Karcher 2500 PSI Pressure Washer
Garden Logo
52 people viewed this question
Top Garden Experts
roeb
john h
Marvin
Marvin
