Samsung N120-12GW Netbook Logo
Posted on Feb 15, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Samsung n120 screen is displaying only vertically - how do I go back to horiz display?
Screen display is frozen in vertical position.
Brian Sullivan
Level 3:
  • Samsung Master 27,725 Answers
  • Posted on Feb 15, 2013
Brian Sullivan
Samsung Master
Level 3:
Answers
27725
Questions
Helped
5664403
Points
79191
Computer users occasionally have a need to rotate, or "flip," a monitor display to be better able to read long documents or to view pictures. Because rotating a computer screen is such a basic function, modern operating systems (Windows XP and up) include hot keys and display options that enable the user to rotate the computer screen by 90, 180 and 270 degrees. Rotating the computer screen allows for more display options. For instance, when rotated 90 degrees, a 1680x1050 monitor becomes a 1050x1680 monitor, which provides more vertical pixels than a standard display.
Windows XP/Vista Monitor Orientation
Minimize any windows or programs to the taskbar. Click the desktop. Press "CTRL" + "ALT" at the same time. Press one of the arrow keys to flip the monitor orientation by 90, 180 or 270 degrees. The left arrow rotates the computer screen 90 degrees; the down arrow rotates the computer screen 180 degrees; the right arrow rotates the computer screen 270 degrees; the up arrow resets the monitor orientation. Rotate the computer screen in Windows Vista by opening the Control Panel, searching for "Tablet PC" and changing the "Orientation" drop box to the desired rotation. b> Windows 7 Monitor Orientation b> Click the Start menu at the lower-left hand part of the screen, and open the Control Panel. Select "Display," then click "Change display settings" from the left column. When using multiple monitors, select the monitor that you would like to rotate. Click the drop box next to the "Orientation:" option. Select the desired rotation and click "Apply." Click "Keep Changes" or "Revert," depending on preference. Click "Apply" in the Display Settings window. Click "OK" to finish.
5 Related Answers
durtopian
Toby Lee
  • 409 Answers
  • Posted on Oct 10, 2009
SOURCE: Screen problem NC10, vertical 'strip' in middle of screen
Sounds like the display is bad and needs to be replaced.
Anonymous
  • 177 Answers
  • Posted on Jul 31, 2009
SOURCE: Samsung N120 Netbook won't start Windows. stuck on black screen.
See if you can download it from Microsoft. It seems to be related to the languge translators in Windows (NLS file).
Dennis Dalisay
  • 52 Answers
  • Posted on Feb 24, 2011
SOURCE: Why does my Samsung N120
connection of the flexible wire with in the screen and the main unit must have a loosing connection..open the screen with a safety precautions and replace a new flexible wire in your unit.
Anonymous
  • 96 Answers
  • Posted on Aug 19, 2011
SOURCE: The screen on my Samsung
It gets frozen on Windows? In any case I would suggest to test Hard Drive first because it sounds like a Bad Sector in it. Then RAM. If both are OK, then I suggest to re-install Operating System. If it's in warranty - bring it back to seller or contact repair center provided. Good luck
Michael Vincent Cruz
  • 868 Answers
  • Posted on Sep 22, 2011
SOURCE: samsung n120 netbook screen remains
Hi possible the Video card is busted on the LCD, get in BIOS see if the screen will still remain Bak if it does then the LCD is busted, get in safemode if the issue is still the same then it is the LCD but if there is Video in safe mode the issue is the video card
To get in safe mode keep on tapping F8 as soon as you power the Laptop To get in BIOS keep on tapping Del or F1 as soon as you power the Laptop
Samsung LED TV, Model# UN55B6000VFXZA turns on to black screen then displays large blocks of colored vertical lines?
check every flat cable main boerd to t-con t-con to display if dont help display is a problem
Thin red line running from top to bottom of screen
What is this thin red line that is on my screen whenever my ...
https://answers.yahoo.com/question/index?qid...
Sep 23, 2010 - There is a very thin red line going from the top of my computer screento the bottom, ... If it's a single-pixel-wide red line from top to bottom it's a failure in ....have thin red lines running down the screen??some are thicker than ...
Thin Vertical Red Line [Solved] - Acer - Displays - Tom's Hardware
www.tomshardware.com > Forum > Displays
Tom's Hardware Guide
Jul 12, 2013 - 5 posts - ‎2 authors
hi all i am having a Thin Vertical Red Line on my Acer LED moniter ... the screen is having a part fail(cable or the screen/control board it self.).
Why is there a straight vertical line going from top to bottom on ...
forums.androidcentral.com > ... > Samsung Galaxy S6 edge
Apr 15, 2015 - 7 posts - ‎4 authors
Just bought the Samsung Galaxy s6 edge yesterday. After I charged the cellphone for the first time and turned it back on there was this straight.
Why are there vertical colored lines all over screen?
Thin vertical lines cover screen on Samsung LCD - AVS Forum ' Home ...
www.avsforum.com/...lcd-flat-panel.../1127410-thin-vertical-lines-cover...
Mar 7, 2009 - 30 posts - ‎25 authors
I have read there could be ribbon cable connection issues so I plan to .... I have a VizioVW22LHD TV,I hooked it up using a HDMI cable to my Toshiba satellite laptop. ... If you have thin multi-colored vertical lines on your tv panel, that do ... my TV on the thin vertical lines come all over the screen and the TV ... my VIZIO E470i-A0 LED has vertical colored lines on ...
Nov 18, 2013
Vizio SV370XVT lines throughout entire display. Not ...
Aug 3, 2012
Thin vertical line on LCD tv
Dec 29, 2007
More results from www.avsforum.com
Vizio P50HDTV Display Problems - Colored Vertical Lines .
Monitor displays half screen sometimes and goes back to full screen later. Some days you get the full screen but today it is half screen one time and then full screen another time. It finally quit...
The monitor have problem in vertical section of the board.Maybe the vertical output or any parts around the vertical ic is loose connection circuit,what we called,cold solder so its better to resolder the board at the vertical section.
I want to adjust my screen , its is streching vertically Please help
Look for "buttons" on the bottom-front or bottom-edge of the monitor.
One button will activate the OSD ("On Screen Display). Through the OSD, you can change the "vertical size" and "vertical position" of the display.
My display is frozen at on. Vertical Lines appear on screen
Try to hold down the off button and restart it, if it still shows the same screen take it for servicing.
1helpful
Zenith P42W34P Plasma Display Panel
Hello, My name is Dave and I can help you fix your Plasma TV. Do you have Black vertical 1.5 inch line or lines on your screen that come and go? Then give me a call. Please feel free to give me a call @ 1-503-432-9904 or message me at [email protected]
Thank you!
Dave,
Top Samsung Computers & Internet Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Jean Thiebaux
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
