That is common. What is happening is your shutter speed is So fast the mirror blocks the sensor when the light hits it. You Can increase you aperture to a height number (f11 for example) and keep your shutter speed below 1/200 to avoid the issue. The only way to avoid the issue is keep your shutter speed slower. Good luck!
It's not the aperture, it's the shutter speed. It's also not the mirror, but the shutter.
The camera's fastest shutter sync speed is 1/200. You must use a shutter speed no faster than that. Due to the construction of the shutter, the frame is not fully exposed simultaneously at faster speeds and thus part of the image is blacked out.
Using a flash, the amount of light is controlled almost exclusively by the flash; the exposure is controlled by the aperture and the shutter speed is all but irrelevant.
SOURCE: how to sync d60 with d-lite kit
You can get an AS-15 Sync Terminal Adapter from your favorite Nikon dealer, which slips into the hot shoe and provides a sync terminal.
SOURCE: I have a nikon d60 and my basketball pictures are
you can try turning up the ISO but this does come at a cost as it may come out with lots of noise(grain) you can do this by half pressing the shutter so the shooting info comes up then pressing the zoom/info button on the bottom left and selecting ISO it should say auto then just select a higher ISO that you find right
i would try to stay away from really high numbers ISO800 should be fine but you may want to push it a bit more
hope this helped
SOURCE: Hi, I have a Nikon D60. Somehow I locked aperture
The lens is supposed to be locked at its smallest setting (largest f/number). You can control the aperture from the camera body, the same was as on a lens without an aperture ring. For example, in aperture priority mode (A), simply turn the command dial. In manual mode (M), hold down the exposure compensation button while turning the command dial.
That was for a lens with the electronics to communicate with the camera. If you have a purely mechanical lens, you must shoot in manual mode and control the aperture by turning the ring on the lens. There should be a small orange slide near the aperture ring, Slide it toward the front of the lens to unlock the ring.
If you need more help, please feel free to reply to this post. Please specify the lens when you do.
Specifications Recommendations
The Nikon D60
is an inexpensive 10 MP DSLR that comes with an excellent 18-55mm
VR lens for about $650 as of June 2008. It was a announced in January, 2008, and sold for about $750 with lens in February 2008.
The Nikon D60 is a
replacement for the almost identical D40x.
Personally I prefer Nikon's least expensive D40
over the D60 or D40x. The D60, D40x and D40 are actually exactly the
same cameras, differering only slightly in their internal electronics,
but differing greatly in their prices.
The D60 is actually a D40 body with
a few more card-clogging pixels, a VR lens
and adaptive dynamic range, but
a slower maximum shutter speed with flash.
The D60 is less sensitive to light then the D40
(its default ISO is only ISO 100 compared to the D40's default ISO of
200). Its less sensitive to light because the pixels have to be made
smaller to cram more of them into the same-sized sensor. Smaller pixels
collect fewer photons than larger pixels. Since the D60 is half as
light sensitive, the D60 has to use twice as long a shutter speed or a
larger aperture, which makes it more likely to make a blurry picture
than the D40. OOPS!
Save your money and get the D40 instead. The D40's faster sync speed
is invaluable for use with flash outdoors, and the extra light
sensitivity in normal use will help make sharper pictures. These three
cameras (D40, D40x, D60) otherwise, for most users, are identical.
Compare them in person and you'll see. Megapixels don't matter.
(I detail the few fine points which are new in the D60 further below.)
I had my hands
on a D60 back in January 2008. The D60 is an
excellent camera, but for most of the people who will buy
it, it's the same thing as the $300 less expensive
D40. I'd suggest getting a D40 and putting the $300
towards more lenses and/or a bouncable flash.
In fact, the faster flash sync speed (the fastest
shutter speed with flash) is more than twice as fast in the D40 (1/500
vs. 1/200), and along with the faster base ISO, the D40 is more likely
to make sharper photos for most people, for hundreds of dollars less!
The only significant feature in the D60 over the
D40x and D40 is adaptive dynamic range.
The D60 does not have any of the other next-generation functionality
of the D3 and D300.
The D60 is just a D40 with more pixels, but
slower shutter speeds with flash outdoors and less basic light
sensitivity due to the smaller pixels needed to jam more of them onto
I
make excellent 12 x 18" (30 x 50 cm) prints from my
6 MP D40; do you plan to print bigger? Really? The
resolution makes no difference unless I'm printing at 20 x 30" (60 x 80 cm) or more.
Since the D60 costs $300 more than the D40, I'd much rather have a D40, 1/500 flash sync for better daylight fill-flash range, a minimum ISO of 200 and $300 left over to buy lenses and an external flash that I can bounce for better lighting. For instance, the D40, 55-200mm VR and SB-400 is a far better way to spend the same $750.
