There appears to be no external button to change the source to play a dvd from a compact player that I just attached. There is a menu button, but that is not one of the choices. I do not have a manual. Can you direct me to a manual and/or solve the problem?
I'm assuming that you do not have access to the remote for the TV. If you do, you can simply press "INPUT" on the remote.
If you have no remote, try this:
Press the "MENU" button on the TV.
Press "CH Down" until "Channel" is highlighted, and "MENU" to select it.
Press "CH Down" to highlight "List and Labels", and "MENU" to select it.
Press "CH Down" to go below channel 1, you should see "FRNT" displayed.
Press "MENU" to get out of the Menu system.
You should now be seeing whatever is plugged into your front connectors.
Simply pressing one of the channel buttons will switch back to normal TV mode. I could find no faster way to access the front connectors without using the remote.
Try pressing the channel button down pass channel 2 and you should see AV 1, press again AV 2 and so on.
I hope this solution works for you. Please take a moment to rate this solution.
It doesn't work. When I pass channel 2, it skips to 99 and then on down. I wish it had worked.
