You can not adjust the track speed it's stuck on highand will not adjust to a lower speed
SOURCE: replaced the motor controls
Is there a sheet of paper under the motor hood? It has the procedures for this calibration of the motor speed. Caution ! You should use a plastic screwdriver to make adjustment to the speed control on the motor controller. It is high voltage
SOURCE: Does anyone know how to remove the plastic foot
you must remove the screws allens including those found beneath the label. be careful when lifting
SOURCE: NordicTrack speeding up for no reason
This make all this adjustments:
Make sure the sensor speed is as close as possible to the pulley withouttouching it. You will see a magneton the face of the pulley; make sure the sensor is aligned with themagnet. There is a screw thatholds the sensor in place that needs to be loosened to adjust thesensor. Re-tighten the screw whenfinished.
Good luck, sincerely.
E.CUADRA
