Question about Kia Vehicle Parts & Accessories
Radio firmware 1.03 - Kia Vehicle Parts & Accessories
How to restore the original firmware in FTM100DR
Sounds like you tried flashing firmware for another region (country) on your radio. I don't know if this was a genuine error or you were trying to wideband your radio, but it usually ends up bricking the radio. If you are unable to flash the correct firmware for the correct region (of the radio), call Yaesu support. They are helpful and will be able to help you figure out a solution.
Welcome to Yaesu com
Jun 14, 2016 | Radio Communications
How do I reset the firmware on a MOTOTRBO radio?
Contact Motorola Solutions.
Get Support
Mark
Motorola Mobility Support
Feb 16, 2015 | Motorola Radio Communications
CANT CHANGE CHANNEL FROM 03 TO 03-1,03-4 AND SO ON.
Do a hard reset to this set and check. Unplug the TV from AC mains wall socket, and re-plug it back after 5 minutes or so, This must make it a hard reset. If it to not help you, seek tech support. If you wish to get more details, surf the following link. There are over two thousand and four hundred posts. All are related to television and other domestic electronic equipment service help. You can get a solution there. Type in the brand name to your device to its search box, can be located at the top right of the display window. It will make search easy. More than Nine Lakh viewers cannot be wrong.http://electronicshelponline.blogspot.com/
May 07, 2013 | Televison & Video
Problem with the Delphi SKYFi3 XM Radio Receiver UNIT LOCKED UP WILL NOT COME ON OR GO OFF
Common problem with SkyFi3 units. You have to press the Volume UP button and hold it while you press the POWER button; this will 'reboot' your radio, then you can try it again to get it to go off.
You will need to update your firmware on the radio using the baby USB cable and the unit plugged into your computer WITH the battery recharged FIRST. Also, go to the www. xmradio dot com website and download the SkyFi3 FIRMWARE update. Then you need to download the "firmware update" into your SkyFi3. If this doesn't fix your lockup problem, you need to call DELPHI customer support, and they can tell you one more 'master reset' method. After the firmware update, it might take 2 or 3 'restarts'. Again, press and hold the Volume UP and PWR at the same time to reset a 'locked-up' SkyFi3. Regards, John
Oct 01, 2010 | Delphi SKYFi3 XM Radio Receiver
The radio on my Coby 610 turns off after 3 minutes of play
I don't think I am actually solving this, but I think I may have a reason why it is happening. I am having the same problem with the radio turning off after about three minutes (I, too, had to reinstall the firmware).
I think the system sees the player as "inactive" when in radio mode and shuts down after a few minutes of "inactivity" -- even though you are, in reality, listening to the radio. The exact same thing happens when you pause an MP3 you are listening to; the system will see the player as inactive (because the music is paused) and shut down after a few minutes.
Maybe there isn't anything in the system (firmware?) that can differentiate the inactivity of just listening to music coming in through an antenna and the inactivity of paused digital music?
Feel free to send this to Coby tech support and see what comes back.
Apr 02, 2009 | Coby MP-610 MP3 Player
Firmware unkown
If you're getting, 'radio firmware unknown'
Then the radio module is dead.
The radio module wont respond to give the firmware version.
Jan 23, 2008 | T-Mobile Sidekick II
Psp
I would presume the 378_PSPRadio0.37Final.zip you downloaded is a homebrew software, which is only allowed to run on a custom firmware, for custom firmware download and information, please refer to http://dark-alex.org/ , the most well known psp developer.
Apart from that, the 3.71 firmware does not support internet radio, the upcoming 3.80 firmware come with a internet radio function, but it would not be as useful as the PSPradio 0.37.
Best choice for you is go for the custom firmware!
Dec 23, 2007 | Video Game Consoles & Games
Sidekick radio firmware
Nov 24, 2007 | T-Mobile Sidekick II
Radio firmware:unknown
Nov 11, 2007 | T-Mobile Sidekick II
Please Help me
MOTOROLA GP-2000 Programming Instructions
Switching between Dealer and User Configurations
- Turn off radio
- Press PTT + Monitor Buttom and + buttons together and turn radio on
- LCD Displays PRO-CLR
- To confirm switching to Dealer configuration, Press PTT. To cancel, press any other button
- Turn off radio. The radio now operates in Dealer configuration
From Dealer to User
- Turn off radio
- LCD Displays PROTECT
- To confirm switching to User configuration, Press PTT. To cancel, press any other button
- Turn off radio. The radio now operates in User configuration
ENTERING PROGRAMMING MODE
If the radio is turned on, turn it off. Press and hold the MON button and turn the radio on. A ringing tone will be heard,which indicates that the radio is in Programming mode. The PW and [] indicators are displayed.
EXITING PROGRAMMING MODE
To exit programming mode, turn off the radio
ACCESSING PROGRAMMING MODE PARAMETERS
In dealer config., Programming mode parameters are grouped into 3 (three) main categories.
RW = Radio Wide
Channel (001 to XXX) and
VFO (Variable Frequency Operation)
User + or - buttons to move from one category to another.
RW < >CH 001 < > CH 002 < > …. < > CH XXX < > VFO
Note : Radio operating in User Configuration is only restricted to PW parameters
Once you have selected the category and wish to view its parameter, use PTT or MON to move from one parameter to another.
Nov 06, 2007 | Radio Communications
Vehicle Parts & Accessories Logo
181 people viewed this question
Top Kia Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Cameron Lewis
Cameron Lewis
Level 1 Expert
Kardoc
Are you a Kia Vehicle Part and Accessory Expert? Answer questions, earn points and help others
