Kirby Ultimate G Bagged Upright Vacuum Logo
Elizabeth Elliott Posted on Feb 15, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Kirby drive gear not working
Kirby bloke
Level 2:
New Friend:
Greenhorn:
A rookie expert who has answered 20 questions on their first day.
  • Expert 88 Answers
  • Posted on Apr 29, 2014
Kirby bloke
Expert
Level 2:
New Friend:
Greenhorn:
Answers
88
Questions
0
Helped
15506
Points
101
You will need a new cam bracket, contact your local kirby agent
Kirby G10D not driving on assist. every thing looks good when in gear turning the wheels the transmition does not turn Why?
First thing to check is if when pushing pedal it moves gears located on the rear Kirby transmission axle (you will have to take cover shell off to see that)
If that works fine then primary belt may be broken. If it is then just replace entire set to make sure that belt type matches gears and the set is not that expensive
Last and the most expensive problem - the main transmission belt within transmission is broken (then I would recommend replacing entire transmission ) Kirby Transmission Troubleshooting
800-775-6586
GoodVac com
2answers
My Sentria is possessed......when we put it in drive......it goes backwards!!!! Help???
I saw videos it may be the transmission because it makes your kirby easy to push. It is working backwards so it may be the gears. This video will work for any Kirby that has TechDrive
Aug 17, 2014 • Vacuums
How and where do find the switch to activate self propel unit in G4 series kirby
To place the kirby G4 into gear - out of Neutral - just press down with your foot, the Gray & Green lever that is labeled N on the left side of the lever, which is gray, and D on the Right side of the lever which is Green (probably for GO). It is located directly below the Power button.
Good Luck
See Pic...
2helpful
The drive on my Kirby G-5 is stuck in forward.
Motor housing will need to be removed and transmission a linkage adjusted. Take to a pro shop for this one.
3helpful
2answers
Kirby G6 clicks while in neutral
Bracket cam assembly (see and buy HERE). It is worn so it does not disengage gears completely. On the part listing you will also find the instructions on how to replace it.
Rocky
2answers
G5 kirby's drive feature isn't working
the gears or the drive is probably worn down or is broken.take it into kirby and they can fix it for you.
Kirby G5 rear wheels lock up completely when in "Drive"
When wheels lock when vacuum is OFF - it is normal. If it happens when Kirby is ON then there are a few things that may have gone wrong
Primary drive belt is broken or something is wrong with plastic gears. See how to check the primary drive belt HERE.
If it is fine and gears are spinning - then something must be wrong inside the transmission. Parts for tech drive are not available from manufacturer so you are on your own. It is not really complicated - 2 clutches that engage and disengage depending which direction you push the vacuum. But if something in there is broken - you have to get a new tranny. It is not like getting a transmission for a truck but it still will set you back by about 100 $.
Good Luck
Rocky
2answers
Kirby g5 vacuum
Either the cogged belt broke, or you will have to pull the transmission and see if something came apart. May have to replace the transmission.
2answers
Gear lever
here are a few links to repair proceedures for the kirby (pictures included)
Transmission:
http://www.greatvacs.com/Kirby%20Transmission%20Adj.shtml
On/Off switch
http://www.greatvacs.com/Kirby%20Powerswitch.shtml
Hope that helps!
Top Kirby Vacuums Experts
Mike Cairns
Mike Cairns
Paul Bade
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
